Hi I have a old 2008 t5, I would really like the soft close I drive a lot of people that don’t know how hard you need to close it. I read it’s possible on the the t5.1 with a lot of time and money. Is the t5 too old? Or is there a aftermarket soft close you could buy?
Fingers crossed here, hoping someone can help me with a workshop procedure for replacing the RH powered door sensor seal?
Keen to know how things come apart
Keen to know if I need to preorder any clips etc before I start?
Hi I’ve got a 2020 t6.1 with ten electric sliding side doors
Offside door isn’t working properly- won’t open with handles or on key- but only as you turn ignition on and push button on dash at same time. The button also flashes, then stays lit up constantly
The exterior handle dose not work at...
Had to disconnect battery this morning when taking air bag off. On reconnecting power latching isn't working. Does it need any specific calibration like the leccy windows?
Hi folks I’ve had a look at a couple of threads but think my problem may be slightly different. Power closing tailgate seems to occasionally have a bit of a meltdown, basically the mechanism goes on and off multiple times unless I open it and slam it shut and even then it sometimes keeps going...
Yesterday my electric slider (ie it has both slider motor and soft close) refused to work with button blinking. I had OBDeleven with me and got the following code:
I was able to operate the door manually though so not a real issue although the door is pretty heavy to use with motors...
So that members searching “electric tailgate” electric tailgate soft close” or alternatively “electric sliding doors” problems can easily find this I’ve started a new post.
I have had the soft close fail on my electric tailgate many times. One time the mechanism had loads of rubble grit in it...
Hi everyone I'm new here i have just gotten a T6.1 (I Think) for work comes up as a T32 H-LN TDI 4M SA if that means anything!
the problem I have on collection the sliding door wouldn't close, its not electric but does have the pull in motors I'm told.
apparently this hasn't happened before and...
Hi all. Just recently the power latch on the sliding door isn’t pulling the door snug tight like it used to. It does close but no longer pulls the last 5mm or so. You can see the gap outside when it’s closed.
I took the latch out and everything seems tight.
Is there something else I can...
Me again sorry !! Recently bought a t6 caravelle but noticed the tailgate not closing properly, still moves a good few mm when shut, at first I thought it was just a worn catch but then I looked on the forum and seen some have power latch soft close, is there any way I can tell if it’s got it...
Huge spec 65 Plate 2015 140 DSG SWB Kombi for sale.
Base Van Spec
Euro 5 140 DSG With 85k miles.
Acapulco Blue.
Full VW Service History.
Cambelt and Water Pump Changed.
DSG With Paddle Shift.
Genuine VW LED Headlights.
Genuine VW LED Rear Lights.
Electric Single Sliding Door.
Power Latching...
I picked up my 17 reg' T6 California Camper from the VW workshop today having asked them to look at several issues including the soft close sliding door. The door has been developing an intermittent rasping/creaking noise when I initially open it (i.e. as it de-latches) which has now become...
Used kit purchased from Pauly for the passenger side sliding door of a 2016 T6 Kombi as featured in the thread linked below, but realistically I'm not going to get around to fitting it.
https://www.t6forum.com/threads/power-latching-retrofit-kits.1584/
Looking for £300 plus postage, or collect...
Ok, yes yet another issue with this new T6.1 shuttle that we have. We have the electric tailgate option and sometime when we shut it, it doesn’t latch fully and even if we open and re shut it several times it still doesn’t latch and we have to press it shut that final 10mm or so.
BRACE...
When I used to slam my VW t6 rear door (it’s not barn doors but the other one I’m not sure of the name of) it used to make an electronic noise after it closed.
Now it doesn’t. How do I fix this? Could this mean someone has tampered with my door?
Thank you
Hi all, I recently broke the plastic piece off the reciever for my power latching tailgate, does anyone know if this is replaceable or will I need a complete unit, the tailgate squeaks like a rusty farm gate now
Help with tail gate closure?
Morning folks. I have a t6 kombi edition with both rear doors and boot lid that, after closing, mechanically close tighter. Except the boot lid is intermittent on doing it and has a small amount of play when shut. Anyone know if it's something dumb like hold the key...
Hello all,
I’ve got a T6.1 with soft close sliding doors, and was wondering if any of you clever people have done an electric tailgate conversion, if so be very grateful for information on how and where you sourced the kit from and cost
Cheers
Neil
So my 67-plate T6 has an electric side door which has been working perfectly until yesterday when, suddenly, it had stopped working. I unlocked the van with the fob & pressed the button to open the side door... Nothing. Tried pulling & releasing the handle... Nothing. Got in the van, started the...
