Bought this and had it fitted but discovered needed a complete new bearing so as that came with a new carrier I have this left over. Was used for about 150 miles. Cost £246 so just looking to get a bit back. Couple of minor marks from fitting but if you’re planning to buy one you could save a...
Hi!,
I was changing the rear springs on my t6 syncro and while shoving the trailing arm down to pop my spring out, there was a "clonk" and the driveshaft seems to have popped out of the diff slightly causing some gear oil to leak out (only a few drips)
Does this just "shove" back in?
