puddle lights
  1. Garyf123
    Sold Puddle & Footwell Lights
    Purchased from Saxoboy but never installed! Set of puddle lights with Red safety lights. Set of footwell lights. £50.00 inc. postage to 'normal' parts of UK! Gary.
  2. S
    For Sale VW T6.1 Mirror Puddle Lights kit for sale
    Hi everyone Have a set of mirror puddle lights/trims/wiring for sale for VW Transporter T6.1 2020>2024. These are for models with factory footwell lights already installed as all the wiring is adapted to connect via these. If you don't have footwell lights in T6.1 you would require additional...
  3. Chopsey
    T6.1 Puddle lights
    Hi I have just bought a 2022 T6.1 Kombi van & it has been fitted with the VW logo puddle lights fitted to the bottom of the door cards, one shows the vw logo & the other one just shows the light on the ground, are these easy to take out to repair or will I have to buy a new one? I think you can...
  4. S
    Stan The Man's T6.1 Ascot Grey build
    Hi all, Just got myself Ascot Grey 2023 T6.1 150bhp DSG Highline last week and absolutely love it! Had a mk4 150bhp highline Caddy previously and unfortunately it was getting too small with work requirements as I am self employed handy man here in Ireland. Took about 3 months to get her built...
  5. S
    Travelin-Lite Puddle / Courtsey lights issue
    Hey all, I hope there’s someone out there who’s a bit of a sparky, as I’m pulling my hair out lol. I’ve recently fitted led bulb replacements for the reading lights and some LED footwell lights, all without problem. However I recently fitted some puddle / courtsey wing mirror LEDs from...
  6. Andysmee
    Utility puddle lighting guide - how to add to mirrors and doors
    This is less a guide and more a walk through of how you might do it. I've called it utility lighting as this is more about illuminating the area round the van than for looks. For projector puddle lights there's other threads and kits that use the door lock latch sensor wiring, and that doesn't...
  7. Andysmee
    Problem with aftermarket puddle lights connected to door lock on 2019 T6
    Could someone with puddle lights do a check for me....switch your engine on and open your door to trigger the door puddle light. Then use a screwdriver or long nose pliers to latch the door latch and trick the door into appearing closed, the puddle light should go off. First look at the light...
  8. RayF
    Travelling-Lite Mirror Lights
    Has anyone fitted the mirror (puddle) lights from Travellin Lite? It says they’re an easy fit and the actual fitting of the lights into the mirror housing will be easy, however vehicle electrics are like a dark art to me and how to connect the lights into the right place so they work as intended...
  9. Mocko1962
    Door puddle lights not working
    Just noticed when either driver or passenger doors opened no VW Logo Puddles working ... the footwell lighting on both sides is still working and overhead lighting working ... is the door circuit courtesy lighting on the same fuse as the footwell and overhead lighting .. seems strange that both...
  10. kearnage
    Puddle lights: mirror or doorcard?
    Wing mirror mounted or bottom of door card? Oppinions?
  11. Martin Gibson
    Mirror puddle lights
    Hello,i have just bought some Mk6 Golf puddle lights for the mirrors on the van. I will fit these at the same time as the dynamic indicators that i have been meaning to do for a while. I know some other people have fitted these and was just wondering if anyone had any advise on cutting the hole...
  12. Barley53
    Red courtesy lights in the doors
    Hi, numpty electrics question; I'm thinking of installing red warning lights in the front doors. I've recently installed door puddle lights by hacking into the courtesy wiring behind the door panels, do you think I would be able to splice into the wiring that leads to the puddle lights (thereby...
  13. saxoboy
    For Sale Welcome/ Puddle Light Kits
    Hi Guys, I have been trying to source a great set of projector lights that complement the T6 as a top quality vehicle...there are many of these projector bulbs out there, but I think I have the best quality ones now...in fact they are as good as, a well known brand that sell them for £80. They...
  14. Barley53
    Door Lights In T6 Highline?
    Hi all, I've just picked up a my19 T6 Highline, my first ever van so I apologise if this is a daft question, but are there supposed to be lights in the side door footwell and the bottom of the front doors? I've scanned the VW configurator and I can't see an answer. Thanks.
  15. Steve H
    Under Door Courtesy Flood Lights
    Do VW do any under door courtesy style flood lights..? I've heard that it may be an option with Sportline side bar fitment, but I can't see anything listed anywhere. Cheers
  16. Hickey
    Side Door Light Bar
    I fancied a light bar by my sliding door for those late night piss runs, decided underneath would be best as easier to run the wires, pretty chuffed with the result only took a few hours
  17. Deaky
    Repeater Lamps In Mirrors.
    @Fish @StudleyGlass
  18. Deaky
    Black trapezoid side bars with led puddle lights
    After being messed around by the dealers I cancelled my order and sorted them myself. Marked the bars where I wanted the led strips to run. I’ve used 5630 SMD waterproof led strip in red. 5630 is the biggest and brightest led chip available on a 10mm strip. I’ve drilled the bars at both...
  19. Diesel9a1
    Puddle Lights
    Anybody fitted puddle lights (Mount under the door and come on when door opened) to their van? How did you mount and where did you connect to?
  20. steveph
    Retrofit: Power fold mirror with fold on remote lock
    I’ve just swapped my T6 electric/heated mirrors to power folding mirrors. And they fold on remote lock :) This approach requires you have the standard electric/heated mirrors. Part of the kit would apply to add fold/unfold on remote lock/unlock to factory installed power fold mirrors - see my...
