raised floor height
  1. C
    Kombi threshold step for panel van - to match floor height.
    Read a few threads on this but would like to hear from anyone who has swapped the standard side step to a kombi one. I've got non slip phenolic plywood for my floor which will sit on a mixture of 9mm spacers and the metal ribs of the floor. Will the kombi step work with 12mm ply only? No top...
  2. C
    Sliding door step height
    Well my vanstyle raised step doesn’t seem to fit with my 12mm ply floor, the bottom section doesnt sit on the base metal... although the rear piece fits perfectly. Any ideas on which others I should be looking at that would fit? It’s for a pannel van, ply sitting on top of the metal ridges...
  3. P
    Deep plastic steps without light?
    Is there available the side steps for the sliding doors without any lights and suitable for a factory kombi (rubber) flooring height??
  4. OllieGBR
    Caravelle Step Light power
    I've searched and I know from @Skyliner33 posts on his build that you need a Caravelle step to accommodate the additional height the floor brings. What I can't find is how this is wired in? Is this powered by your leisure battery or spliced from the door switch?
  5. Skyliner33
    Caravelle Step Height?
    Looking for some help. I’m thinking of putting a Caravelle step inside my drivers door step. I’m just wondering if it will be the correct height for my carpet.
  6. andy greenwood
    Problems Fitting Kombi Sliding Door Step
    I've put down a new 12mm ply floor on top of 9mm batons & then altro on top. I have really struggled though fitting the new kombi step I've purchased. I cant seem to fit the step whilst locating all six of the securing screws, i cant get the 3 horizontal ones and the 3 vertical ones all located...
  7. Sam Lawson
    Caravelle Carpet In Passenger Area
    I'd like to replace the carpet in the passenger area and boot area of my Caravelle with rubber flooring. Does anyone know if this is possible? I've found companies like Rugs for Bugs that offer a rubber flooring to go over the carpet, but ideally i'd like to get rid of it completely. The rubber...
  8. Sjacko20
    Sold T6 Kombi rear step threshold cover.
    After installing power latching, I am selling the original threshold cover from my Kombi. It was removed at about 1 month old and is in excellent condition. 1BB6571C-93CB-4BD7-A45D-15FCB3453329 by Sjacko20 posted 15 Feb 2018 at 12:41 A8C3B9CE-294B-40B2-A2B7-3853FF9ECE20 by Sjacko20 posted 15...
  9. Diesel9a1
    Trims and steps after lining
    So when you silent coat the floor, lay battens inbetween the ridges, some thermal insulation(?), then ply flooring and finally 2mm Altro, this floor height is less than the manufacturers rubber flooring. How do you finish the side door steps, the cab to rear flooring edging, rear tailgate...
