Hi all about to start my barn door to tailgate swap, can anyone confirm the routing of the pipe/hose supply from washer bottle to tailgate for the rear wash wipe..I can see its part of the tailgate loom then connects to rest of the feed pipe which will route with the main wiring loom along left...
Hi there,
The two tabs (marked in red) appear to be the two bits I need to remove to allow the wash/wipe stalk to push forwards , in order to operate the rear window wiper and washer.
Looking at the electrical contacts on the back of the switch, it seems that the wiring and contact tabs are...
After a visit to the safari, the kind baboons decided to sit on my rear wiper and twist it 90degress downwards lol. Only damage to the arm so easy fix.
Just wondering if anyone has one going spare and if not any advice on best place to get gen part from (other than VW)....
Hi folks would appreciate a comparison test!
Rear washer nozzle was missing, turns out previous owner had snapped it off so had to drill out the plastic that remained. Fitted new nozzle. Only squirts halfway up the rear screen.. is this lack of squirt range normal? Is it a sign of my pump being...
Hello everyone
Has anyone had their radio unit and rear wiper falling to turn on ? I don't know if the issue is related but I've checked all the fuses inside van and in the engine compartment and it's all good. I also have power going into the radio.
Could I be so unlucky that both went bad at...
I need a vin number for a t6 2018 would be ideal. Has to be a tailgate van, preferably with rear window heaters and wiper.
I know this may sound dodgy, but its not :) im using VW Erwin system to download wiring diagrams and repair manuals. Currently doing it for my van, using my vin number...
Is it possible to retrofit a rear wiper to a tailgate on a 2021 T6.1?
There are some (factory made?) holes on the inside skin but it's not obvious which is the correct motor.
Do you know the correct motor part number?
Many thanks,
Has anyone had to do this? Mine has split somewhere and I’ve got water leaking from just behind the top of the b pillar. Just wondered if it can be accessed anywhere or if there are any joins in it. Thinking it might be easier to just pull a new pipe through and swap the connections over...
I recently got back my T6 from smash repairer, after fitting a new tailgate (no other visible damage).
They used the existing tailgate wiring harness. ALMOST everything works OK - but there's a mystery. Rear wiper would not work. Auto Electrician says there's a wire broken somewhere between the...
Hi all, I have fitted a tailgate with rear wiper. I understand I need to add extra wires etc but I read that the front wiper stalk can be modified by filing away a stop and it will allow the stalk to be pushed forward. Does anyone have any information on this? I have a spare set of stalks in...
Apologies if this has already been covered but I have searched the forum and cannot find the information I am looking for.
I am about to convert a 2013 T5 from barn doors to tailgate. The tailgate is from a sportline and has a heated window and wiper I would like to use. I understand...
I'm currently looking at a basic startline model van with a tailgate, however would want to convert this to having a rear window and also adding a rear window wiper (not currently on the van). Whilst id have no problem at putting the window in, can anyone please advise if fitting and...
Woke up this morning to find that someone had pulled the rear wiper off and the plastic cover. I can’t tell if the remaining bracket (shown in the picture) is damaged or not? If anyone could let me know if it needs replacing and a link to the correct part would be really appreciated!
Evening all, my PV tailgate has just had a rear window installed and carpetted and I've just put the curtains up. I have a void centrally where I'm guessing the rear wiper motor would sit in a casing ?
I can see my mobile phone or similar disappearing down it from time to time when Boris let's...
Hi All
Got a replacement rear wiper plastic cover for t6.1 but having problem getting it to fit flush - is it the wrong part or am I fitting it wrong?
I have tried unsuccessfully to source a silicone wiper blade for the rear window of my T32 Petrol TSI Kombi Highline window van 1984cc ( 2018 ). Please can anyone help me with finding this and for the front wipers which I will need in the future? Are there any silicone refills available? My...
Im deleting the rear window scraper, and I'm wondering if anyone could tell me where to look on VCDS to find an option to deactivate the rear wiper, or more precisely the washer function on the stalk for the rear window. I was hoping to leave the hose in the tailgate not having to worry about...
