reimo roof
  1. BigYoeKing
    Reimo pop top: EasyFit or SuperFlat?
    Hi guys, I'm looking for a pop up roof for my t6. I chose reimo and now I'm deciding between easyfit and superflat. don't know how it is with the installation? superflat is also self-adhesive and just sticks like easyfit? Thank you
  2. DreamingT6s
    Finally got my first T6
    So, the day finally came when I took delivery of my 2019 Highline 150 manual SWB in Mojave on Friday. Already had 2 nights away this weekend and absolutely love the van - especially the wider Reimo Variotech bed. Thanks to all on this forum for the support so far, be prepared for many more...
  3. D
    Interior height Reimo roof with bifold bed
    Hello everyone! First post! hopefully I put it in the right spot. I'm based in Italy and I'm having trouble finding a converter that would install a rear opening pop top on my Caravelle with rear AC so I am reconsidering the more "standard" front opening one. The choice would be a Reimo EasyFit...
  4. W
    Conversion 3 years on
    Just before lockdown I bought a T6 and had it converted….long story of parts shortages, variable fitters and being stuck in lockups while we were all at home. Well that was 3-4 years ago and we’ve had a blast in the van since it’s been finished. However now I have some little niggles I’d...
  5. R
    Reimo folding bed issue
    Hi, Has anyone ever had an issue with their Reimo folding bed base being noisy due to up/down movement while driving? The hinged sections are very easy to push up a few cm while the pop top roof is down and so whle driving even over slight bumps in the road the bed flexes up and down and makes a...
  6. C
    Reimo Roof: Leak around Strap Bars
    Hi there Happy New year to all. I wonder if anyone has had the same problem and if so, what they did about it. We have a leak which seems to be located around the Strap Bars attached to the Roof Part. (the little metal brackets where you thread the straps.) I put a picture attached of what i...
  7. Lostineurope2
    Thule omnistor 4200 fitted to reimo multirail
    Hi Does anyone with a T5.1 with a reimo pop top have a Thule omnistor 4200 fitted to a reimo multirail with the specific mounting brackets? I’m trying to get an idea of the height of the awning when fitted to the rail
  8. N
    Need advice on closing Reimo roof
    hi there we are trying out the camper vans features on our drive - re have reverse pop up reimo roof - I think its closed properly but how can we know for sure, hubby is not so sure if it is - how can we check ? Especially the front of van end which is the bit hubby isnt sure about - any hints...
  9. D
    Leaking Reimo electric roof
    Our new (6 months) T6.1 conversion has a Reimo electric roof that leaks. It seems to be coming in along the seams around the side ventilation windows. Has anybody else had this problem? The van has only been used in the rain twice with the roof up and leaked both times. The company who did the...
  10. A
    Noisy Reimo roof?
    Bought our brand new converted camper back in the Spring (having never owned one before and therefore having nothing to compare). I am trying to gauge whether the slight noises that my roof makes are 'normal' or need investigation. Silence when going in a straight line but when cornering...
  11. N
    Reimo roof out of alignment/Twisted
    My reimo roof has gone out of alignment, as you can see below. You can see that it doesn't sit straight at the front and the hinge has moved on the offside of the van, which makes sense as the roof is skewed at the front to the nearside. The hinge is fixed in the right place on the nearside and...
  12. CALLAKN
    Just bought a Reimo Poptop - Solar panel?!
    Hello! I've just pulled trigger on a all singing all dancing Reimo pop top, and thought whilst its in, ill get them to fit a solar panel and run the flex to the CTEK. (I know when I did the 12v system, its all set up ready for a solar, just never ran the cable to the roof at the time!!) Any of...
  13. T
    Upgrading Reimo roof mattress
    Hello everyone.just joined and hopping someone can help me . I have at6 with Reimo roof and bed , i am trying to find out if you can put a duvely mattress topper 50 mm up top and leave it there with the roof down duvely said you can't .
  14. I
    Reimo Easyfit Pop Top on T6.1- Height and Canvas Questions
    Hi all - looking for some advice on those who have a T6.1 conversion with a Reimo Easyfit pop top roof (with the front spoiler). I have 2 questions: 1) Height - I know that this raises the height of the van by 7cm according to the Reimo website. However, it also states that it is fine for most...
  15. O
    Reimo pop top delaminating ? paint bubbling
    Black Pearl T6, 2019. Many parts of the roof are covered in small bubbles in the paintwork which started happening after approx one year. Looks as if the paint has detached from the base structure (fibreglass)?...and is ”popping”. The body shop say that they have seen it many times and it is a...
  16. M
    Replacement Parts for Reimo Roof
    Hi all .... I have a Reimo pop up roof and to the rear of it on the inside are two strips of plastic/perspex (?) which when you close the roof assists the canvas coming inwards to avoid getting trapped. One of these has snapped. Does anyone know where I can get spares? Thanks Mike
  17. Ethan Andrews
    SCA / Reimo fitted abroad
    I wondered if anyone has taken their van across the continent to perhaps France, Belgium, or Germany to have a roof fitted. The fitting cost in the UK is quite significant once you factor in shipping costs. It seems a no brainier and nice idea for a road trip to take it over. Pre COVID I priced...
  18. R
    Awning rail under a Reimo EasyFit roof?
    Hi All, has anyone fitted an awning rail under the edge of a Reimo easy fit roof? If so do you have any Detailed pictures I could see please
  19. Gwyn
    Reimo roof - hairline cracks
    After some advice, while cleaning the van yesterday I noticed some very faint cracks in the roof Is this something to worry about ? Only got the van back from the converters end of January and hasn’t been used yet due to the lockdown Thought I’d ask your advice first before contacting him...
  20. C
    Exploria Reimo Or Kernow Cali Roof?
    Hi folks, I’ve a T6 velle and weighing up whether to put a second hand T6 Cali roof in with Kernow or go to someone like Exploria and have a Reimo roof. The reason for narrowing to these two is the finishing trim. With Kernow/Cali it will be like factory with the velle and Cali trim being able...
