reversing camera
  1. CKZ 102
    Sold OEM Reverse Camera
    As per title. I have an OEM Highline Tailgate camera. Planned to install this, but upon taking my can apart I turned back, and decided I’d live with my parking sensors! Part number: 7E0 980 121 Off a 72 Plate T6.1, believed to be compatible with T6/6.1 with the appropriate MIB. These are on...
  2. A
    High level reverse camera install
    I have a 2011 T5.1 campervan and I have just installed a new Kenwood head unit that pretty much works. Filled with that confidence boost I'm thinking of trying to install the reverse camera myself. I really want it for when I have bikes on the tow bar carrier and therefore want to install it up...
  3. C
    -T6 Rear Parking Camera out of Alignment
    .I have an OEM parking camera with Discover media display, I had a new screen fitted with VW under an extended warranty, now the camera image is incorrect with the green guidelines, I have barn doors, is there a coding I can use to realign, it is as if it is set for a tailgate and not barn doors?
  4. P
    Barn door camera location
    Hi, I’ve bought a reverse camera from Vagtec and the printed guide is impossible to follow! Any idea where I should be mounting the camera? I’m not sure if it should be positioned centrally or to the far right of the door. I want to make sure that the parking guide lines are positioned...
  5. HoopDub
    For Sale Barn door outer number plate light plinth with camera
    Barn door number plate light plinth. I've retro fitted a genuine vag reversing camera into it. Camera was purchased as a kit, but i can't for the life of me remember where from, pretty sure it was a german site. Anyway its just the plinth, lights and camera. The wiring from front to rear is not...
  6. X
    T6.1 Reverse Camera retrofit can it be done cheaply
    i have a 2021 T6.1 shuttle base S model and i am looking to retrofit a reverse camera for it, are we able to just feed a video signal from a reverse camera powered on from the reverse light on the back ( the green and white wire) to the back of the radio if this is the case this would only...
  7. C
    Reverse camera images are intermittent
    Hello all, Had a front and back camera installed by the excellent team at @Dav-Tec. Also reconditioned discover media headunit to replace an aftermarket unit that was not compatible with said camera. All working great until this week. No image comes up in reverse? Rear sensors still working...
  8. M
    New Kenwood head unit reversing camera and parking sensors at the same time
    Hi Everyone, I'm reasonably new to the T6 life and have a 2019 kombi with the standard VW headset (it has carplay and android auto). My van has the from factory revering camera and parking sensors (front and rear) - is that park assist? I'm looking for a new head unit with wireless carplay and...
  9. Deandubya
    Buzzing relay when engine on when in reverse
    Any electric guru’s can answer this..? T6. just changed my Halogen rears to LED’s. Linked up & sorted great. Tried the lights, all working as they should. Thought I was happy. So ignition on, put into reverse lights on great, lights on. Turn on the engine, select reverse & I get a buzzing...
  10. E
    RCD330 reverse camera suddenly stopped working
    Hi there, I installed a Noname VW RCD 330 with reverse cam into my T5.1 and all has been well for a couple of years until I took photos to sell it and would you believe it’s decided to stop working. I get the error “the camera system is not available” or something very similar. At first I...
  11. R
    Reverse cam with moving lines - parts list?
    Does anyone happen to have a parts list to install a VAG reverse cam with moving overlay lines in T6 (tailgate)? Thanks
  12. B
    T6.1 Highline Reverse Camera - KA1 from factory?
    Hi, Just wondering if anyone can shed some light on this. I’ve tried searching on the forum and found that the lowline camera is KA1 and highline is KA2. I have a 2024 PV highline and with factory fit reverse camera but only have the static guide lines… but being Highline I thought I should...
  13. bennythestump
    6.1 Reversing Camera Resolution
    Morning Folks! I picked up a 22 Plate Kombi yesterday and am a little disappointed with the quality of the reversing camera. I have the Discover Media Navigation Head Unit (with 2 knobs - no buttons) and the resolution on that looks pretty sound. When putting it into reverse it was like playing...
  14. C
    Retrofit Reversing camera
    Hi. I have a T6.1 tailgate, Highline with reversing parking sensors. I want to have a reversing camera, please could you advise as to whether I just need a reversing camera attached over the number plate or do I also need to replace the dashboard console? Any help would be greatly appreciated.
  15. Danpearson1986
    Aftermarket Reversing Camera to Discover Media
    Good evening. I've purchased a volkswagen reverse camera input interface harness. I have a discover media radio. I'm wanting to add a reverse camera to the radio. The description for the harness says: Adapter harness to add a reverse camera to an original volkswagen transporter T6...
  16. N
    Wiring diagrams
    So as you can tell from my name I'm a newbie owner of a 2011 T5.1 Transporter. I recently had some niggles when getting an eSafety certificate for renewing my registration (the Australian (NSW) equivalent of a UK MOT I guess) because the rear number plate lights on the tail gate were not...
  17. G
    Reversing camera wiring help
    Hi all, A colleague has given me a reversing camera for my 2016 Caravelle as a birthday present. I have the Discovery media head unit. I have searched for previous posts and watched some YouTube videos on the wiring layout but non appear to match the cables on this camera. I am still puzzled...
  18. Badjamin
    Failed...
    Edited I'm here to vent. I have a T6 and a wolfbox G840s that I have utterly failed to install myself today... the hardwire kit I bought online (cheap) was faulty. So I went to Halfords and bought their hardwire kit. Oh what a meal I made of routing the wires! - BUY CHEAP BUY TWICE only myself...
  19. B
    For Sale 2019 T28 102PS Highline Kombi Conversion, 6-seat, Tailgate, Reversing Camera. £24,995 + VAT
    Hi Guys, We are very reluctantly selling our beloved 2019 VW Transporter T6 T28 Highline SWB 102PS Kombi conversion due to her not getting the use she fully deserves and another family can offer her. - Van: 2019 VW Transporter T6 T28 Highline, short wheel base, 102PS, 5 speed manual. Air con...
  20. Leemondo12
    Kenwood DMX7722DABS Reverse Signal
    Hi All, I have the Kenwood DMX7722DABS head unit fitted to my 2017 Euro 6 Transporter, I plan on fitting a reversing camera before carpeting. Question is does the head unit pick up a reverse signal from the CAN system or do I need to add a reversing signal to the head unit? I have the CAN...
