do i splice it in to the Reverse (purple) or find an ignition live? i believe i shouldn't wire it into the reverse bulb wiring loom due to canbus errors.
Head unit= Pioneer SPH-DA77DAB
Interface= connects 2 FKIT-VW-66
Reverse Cam= Road angel RA 8100
if that helps.
also tidied up the leads a little
Hello! So basically I installed an auxiliary 18W reversing light underneath the rear bumper and now have no reverse lights.
I connected the positive to the rear left tail light's reverse feed (pin 2 green/black if I recall correctly) and put the ground to a chassis bolt, not the tail light's...
Hi, I have a 2018 t6 with the standard rear lights with only one reverse light ( which is next to useless anyway). I need to upgrade in some way in order to see better when reversing, especially driver side. Anyone fitted anything what is available lately. I don’t mind if it’s halogen or led...
I know variations of this question have been asked but I can’t seem to find my variation!
I have bought one of those rear view mirrors with a front facing camera and a rear camera.
It all works fine but it has a cable at the camera end that you are supposed to tap into the reverse live cable...
I have a fault where the reverse light and sensors do not work when reverse gear is selected.
When I monitor parking aid input signal on VCDS the state does not change when I select reverse.
The reverse lights and parking sensors do work when I try them on the output test on VCDS.
After...
We just got the tow bar programmed in and they told me at the time that if the light-bulb error lamp comes on the dash and the indicator clicks at double speed then there is a bulb fault, but all the lights seem to be working fine!?
Only light not coming on is reversing off side (driver) but...
Hi all
Looking for some advice. Got no reverse lights. Took cable off reverse switch today and shorted which turned reverse lights on, so electrically all ok from cable back. Replaced reverse switch and with new switch on I depressed plunger and lights worked as they should, but when switch is...
Hello everybody,
Not so long ago ( transporter t6 2019 barn door ) the little van on my dash kept telling me the back door was open ( it wasn't ) sent to vw, they said cable from front to back has got damaged, installed the new one at the front, and told me where to connect at the rear ( yet to...
I have a Road Angel reverse camera that centers between the number plate lights. I have drilled this point and placed the cam and leads through.
Now I need to access the +reverse light wire from this point.
Has anyone installed a rev cam in a T6 tailgate camper???
Looking for a genuine reversing beeper part number and location where they mount it in the factory. I mean the one that beeps continuously when in reverse on the outside of the van. Anybody?
Good morning all, first post on here but have been using this forum for guidance for some time now, and thank you to @Pauly for accepting me.
So he is where I am, I’m looking to install a wired aftermarket camera from ADT and fit it to my OEM composition media head unit. However finding it...
Hi - just been fitting a reversing camera (Autovox V5 Pro) to my 2018 T6. While doing this I've removed part of the roof paneling and disconnected one of the rear interior lights (not sure if this is relevant). When I've tried to find the reverse cable to connect the reversing camera, I've found...
I’ve had a new pop top roof fitted but developed a reversing sensor fault in the process!
VCDS says 2 faults - Rear right parking aid sensor short to plus and also rear right parking aid sensor open or short to ground.
First thought is screw going through cable or cable sliced at some point.
I...
Looking for best place to take the feed for a reversing camera - I've seen the thread below so know the green/black is the one to use (and identified this going into the light cluster) but would rather take from behind the rear barn door panel assuming it routes that way? @Deaky is the photo...
I've been trying to fix this myself / with our converter, but could do with some advice, please. I'm stuck!
T6 LWB 4motion 18' plate DSG. Rear camera, rear parking sensors.
I've also read this thread, though my problem is different. My fuse is not blowing.
Rear Camera Oem Cable...
I’m hoping one of you technically minded gurus can help me out as I've spent 3 days trying to get this reversing camera installed with no joy!
So here goes, bought s VW T6 RVC from Motormax a few weeks ago in the hope of fitting it to my T6. I have the Discovery +Navi head unit so it should be...
Hi. Looking for some help and pointers.
I'd like to fit a camera pointing rearward. Mainly for reversing but if it can act as a rear view mirror then great. Happy to have an over the mirror screen.
So are there any suggestions? Oh and easiest way to power it. I guess if it's rear view linking...
