Purchased from Gendan UK
Genuine cable. Updated to latest firmware today.
For all VAG vehicles
3 VIN version and I have used 1 VIN - so 2 left
You only use a VIN if you are doing any coding and adaptions - reading/clearing fault codes does not use a VIN.
I used this for coding needle sweep...
I am looking to purchase VCDS. Does any know a good place to start looking to get information on using it. I have used VAG Com in the past but only to read fault codes and reset them so I know some of the basics.
Excel 2016 spreadsheet for decoding T6 BCM Codings, Adaptations and Measurement Blocks.
The decoding procedure is straightforward: just copy coding string from VCDS, OBDeleven, Carista etc. to the cell. An Excel function spreads out the...
Hi, decided to sell my Ross Tech VCDS HEX V2 10 VIN version.
Bought new in 2021 from Gendan (original receipt included). Used a handful of times on my T6 back then and sat in a cupboard ever since so 9 VIN registrations remaining.
Just plugged in to my laptop today and updated to latest...
Looking to buy VCDS for my new Transporter T6, i know i need V2. Looked on rosstech and have 4 different resellers listed, anyone have any recommendations? Also any that give a wee discount ? ;)
Paul aka Shaiboyuk
VW T6 VCDS Coding Guide
This document contains every coding entry currently available via VCDS
This is intended as a handy reference guide for people wishing to perform changes using VCDS, removes the need to waste time searching through...
