sagging rear
  1. michellecrown
    Poor traction off-road with my camper
    Hi The conversion company put these tyres on: 255/45ZR18 103W ultra arz4 for my T28 6.1 transporter but I can’t see whether these are the best for grip. We have moments where grip on steep roads in the Lake District have skidded (possibly not helped by the fact it is an automatic), and we are...
  2. S
    rear end wobble
    Hello Guys, My t6 seems to be wiggling its rear end when it hits a pothole, man hole cover. I have just had the 4 wheel alignment done (all though im not sure its been done correctly) and all though its better its still not right. van is a full camper on solows, all springs look ok, none broken...
  3. 4wdMotion
    Making decisions on Rear Suspension for T6.1
    Hi, I have searched and read many posts, experiences, solutions and advice on the T6 Forum including the ‘back heavy and traction thread” about suspension issues and seeking to make a decision on my options. I have met and read about @TTKT solution and also read @AussieMick posts from the Forum...
  4. C
    Saggysaurus
    Hi all. My converted t28 is a little on the rear saggy side. It’s currently on the original springs/set up and wondered what are my options to straighten it out as well as lower it a bit? Thanks
  5. Shaun P Bass
    Found T32 Rear Springs + Shocks...N/East
    Hi all. Looking for a set of T32 standard rear springs to boost up my back end on my 2017 T6. Maybe shocks also. Ideally located within 25 miles of TS13 (N.Yorks/East Cleveland) area...or poss post to me?.. Many Thanks Shaun..
  6. C
    T28 spring and shock ‘upgrade’
    Hello. I’m not overly happy with my current ride height. It’s just the std t28 set up but fully converted so I suspect I have a saggy arse. I was thinking lowering springs but fear the ride will be harsher. I have zero intentions of adjusting coilovers once on however I heard that may...
  7. Barley53
    Camper + towbar = sag
    Hi, I've got a t28 with full camper conversion, there's the usual sag over the rear which to date hasn't bothered me over much, but I've recently had a towbar installed and this added to the weight of the conversion plus the occasional passengers, reading past posts on the subject it seem...
  8. D
    Suspension recommendation for campervan.
    Hi Guys. I must say at the outset that I have absolutely no technical knowledge whatsoever so I would really appreciate some advice please. I have factory order for a T6 Kombi Highline SWB T32 15o DSG, delivery September. It will be going for a camper conversion straight away! I would like to...
  9. Eli
    Suspension needs tweaking
    So the van lowered on HR Koni’s but the suspension needs tweaking. Currently the front is on 370mm and the rear is on 400mm. Question is do I bring the rear to match the front or front to match the rear bearing in mind it’s a Caravelle?
  10. Mbr_tattoist
    Sportline standard suspension? Any good for my saggy camper?
    So a friend is giving me his standard sportline, 30mm lower suspension. Reason being I have a t6 was102bhp bog standard t28, now it’s fully campered the weight at the back sits the ear a little lower than the front, it’s actually around 3-4cm lower so as I’m getting the shockers from him which...
  11. S
    Rear Springs Question
    Hi all, I’ve been worried about my saggy arse for a while (I’m at that age!!) so after reading on here I decided the solution was to put some T32 springs on there thinking the original springs must still be in place. Anyway I decided to look under the van to check and the springs are actually...
  12. W
    Fitted T32 rear springs but still got a saggy rear
    Hi I’ve got a 2017 T30 on standard springs. Since conversion it has been sitting low on the rear end. I recently ac some T32 shuttle rear springs from a forum member and had them fitted yesterday. Unfortunately the stance still appears similar to before. Is this to be expected? I was hoping...
  13. moto
    Water tank causing saggy rear. Solutions?
    Morning All. Can anyone recommend suspension specialist who could help me, ideally up to 100 miles from London? Thanks Just had a water tank fitted and was assured it will be postioned for perfect weight distibution, but when full it seats much lower at the back. To be fair drives great, no...
  14. Welsh Girl
    Suspension Confusion!
    Evening all, I have seen a lot of chat regarding suspension, in particular, the lowering of it and I wanted to ask what is the reason behind this? Is it safety, good looks or fuel economy? Or a combination? My van is definitely heavier (obviously) following the conversion though I feel it...
  15. J
    Eibach Pro 50mm springs sag when towing
    Hi I have the eibach pro 50mm springs from custom vanz and standard dampers. The van sits great but if I hook my bike trailer or put a bit of weight in the rear it sits lower than the front. Is this because the standard dampers are not sufficient , if so do I go for a B8 Bilstein? Cheers James
  16. VanDamMan
    Review: CRS Performance UK
    Very pleased today ...had fitted Koni dampers fitted with EBC yellow stuff pads ......Quick..Friendly..and listen’d to my needs......my T32 204 auto had a habit that it wanted to lift the front end and spin the wheels when pulling away (Steve. Recommended adjusting the lift on the dampers...
  17. Simon Carne
    Balancing out springs
    Hi I have a T28 with a full conversion and it suffers with a saggy back end and vague steering. I was considering getting some T32 rear springs fitted but saw these from Transporter HQ...
  18. Vanman
    Suggestion To Correct Stance After Conversion
    Following the completion of our camper conversion, I notice that the van looks decidedly middle-aged (ie its backside has gone south). It is a t30 and I wonder if a spring change to t32 will do the trick. Not a fan of lowering the van to compensate. It’s not really that far out, but if there is...
  19. P
    Saggy rear T30 camper
    A6EC0E8D-1E54-41C1-9278-D83CB6AD766F by podiopie posted 5 Oct 2019 at 16:28Hi, Where can I go to get Eibach adjustable Lowering fitted? My van isn’t level due to the full conversion in the rear. I’ve fitted cobra springs as got it lowered to 40mm and was told this would level it out but it’s...
  20. M
    Will T32 springs raise my sagging rear-end?
    Does anyone know what rear springs i can throw on my new t6 lwb highline t30? Its always loaded and sagging a bit on the rear, im tthinking 3 grey paint mark springs from a t32 but I've read people saying 4grey paint marks? Has anyone done this on their van Cheers for any help!
