I have an alarm going off on the Sargent panel when plugged into EHU and charger switched on.
Beeping and flashing green light at top right - stops when disconnect EHU (which was connected to house socket - only way to stop it).
Charger is EC155 and controller EC50.
It also has a solar...
Hi all! Some advice please on a Sergent EC50 problem please.
My leisure battery is fully charged (tested on voltmeter at 13v). I have a solar panel which constantly charges and of course when I plug in to mains.
Problem is, when I select L battery on the EC50, it alarms and flashes red LED by...
Is there a plug and play upgrade for the EC50, I’m thinking maybe a touchscreen version? The existing unit is fine (we’ll see below) but having recently updated the Planar heater control I wondered if there was anything a bit more ‘modern’ looking?
Also it has started only powering up the heater...
My Sargent EC50 control panel recently started alarming. When I checked the voltage indicator was showing 14.7 - hence the alarm. I took the seat out and put a meter on the battery and it was 12.8, however the voltage meter (as in the video) showed a different voltage. I've checked all...
Hello. I've lost power to my control panel, Sargent ac50. I had presumed the on/off switch was a simple spst switch that just fed the lights and pump switch and battery monitor switch. but all literature talks about this switch using an external relay to control the on/off function. I can;t...
Any advice would be great.On my Ec50 control panel I click the L Battery and all the led lights come on to show a full charge.I click on the V Battery and it’s shows the bottom led as Red.Does this mean my vehicle battery is not charging.It starts first time no problem or I have I got these L...
So I am a novice when it comes to all things T6/Electrical, hoping to get some advice if possible. A little bit about the setup I can see in my T6.
Bison BXC31MF Leisure battery
Sargent EC155
Sargent EC50 control panel (no photo).
Firstly, I cannot see anything else connected (split...
Hi All, I'm looking for some advice if you can help. I've recently purchased a T6 Highline converted camper and I have no clue what I should and shouldn't be doing to ensure that I manage and charge the leisure battery correctly. I've taken photos of what's been installed during the conversation...
Hi All. Just joined yesterday. VW Camper-conversion owner, after some advice.
I've had my VW Camper-conversion for over a year now with no issues at all, she runs like a dream. Recently been noticing issues with the power setup. It has Sargent EC155 PSU, Sargent EC50 panel and a PMW Solar Charge...
