sat nav
  1. M
    No google maps gps signal
    I have look high and low but can't find an answer. So it's like this, i have no gps signal in the T6 it just keeps saying "looking for gps signal" or "re-routing" i have been in my hyundai van today and as nornal no problem it that. it's a Samsung S24 if that helps to shed any light on the problem.
  2. S
    Sat nav lost...
    Hi guys I had the infotainment system replaced a couple of week back under the all in warranty due to the failed touch screen issue but I've just gone to use the sat nav and it thinks I'm in northern Germany!! before i take it back to VW again... anything simple I'm missing? ta
  3. Gillon Johnstone
    What’s the best head unit available?
    We are wanting to replace the standard infotainment system but do not relaly want to pay the £1400 for the Kenwood system, can anyone recommend or suggest a much more affordable alternative please and thankyou
  4. J
    T6.1 head unit doesn’t have Sat-Nav
    Can anyone shed some light on this for me... I have just got a T6.1 highline... It was first registered last December... But what I can't understand is... How come it doesn't have built-in sat nav, I thought that a van of this age would automatically have it... Any help would be greatly...
  5. M
    MIB3 - Navigation Database Update (Non-EU)
    Hello all, I got a Tiguan 2021 from Germany and shipped it to Egypt. I have the same problem that was reported here (How To: Using Discover Media Navigation System In Non-EU Countries; E.g. Morocco, UK), that the navigation is not working in Egypt. Unfortunately, I cannot find a SD card in my...
  6. smudger28
    Sat Nav GPS stopped working
    Hi guys T6 Transporter 18 plate. Hoping someone can help? I’ve been using Apple Maps via my Infoentertainment through Apps and it’s been working fine until yesterday. Basically the map comes on the screen but the pointer does not move. I tried the infoentertainment Sat Nav and that’s the...
  7. F
    Will my sat-nav work when I’m in France?
    Hi will my sat nav work in France? I think it the media one Has the option and when I put the sat nav post code it works. But then I’m thinking will it actually work over there ?
  8. shaiboyuk
    VW Sat Nav Map Update without SD card
    Hi, So got my van, but the dealer (not VW) couldn't find the SD card for sat nav, but "promised" would get one asap. I tried the DiscoverCare app, and seems to suggest that you can put map on a standard SD card and it will work.... Tried it, and still says "Navigation database not available"...
  9. C
    SD card for Discover Media sat-nav
    I have just bought a new sat nav sd card from Sat Nav Sytems. They upgraded the radio to the sat nav system some time ago. The issue I have is when I put the new sd card I get this message on the screen. When I put the old sd card back in, everything works fine. I have spoken to them, & they...
  10. Pauly
    VW Sat Nav Map Update Nov 2021
    VW have recently released (29/11/21) the latest map updates for T6s with sat nav headunit/discover media Due to the increased size of the new update DiscoverCare is unable to update the software for you, it will run the process and take its time downloading the update (can take up to a few...
  11. Dilbert
    Discover Media Navigation System: full update 1730 too large for original SD card [Solution]
    The original VW Discover Media Navigation System (at least older ones) came with a VW 16GB SD card. The latest map update version 1730 Europe – Bundle 1 is too large too fit! https://app-connect.volkswagen.com/mapupdates/download/#download Interestingly the VW DiscoverCare program does not...
  12. S
    Satnav colour screen changes
    Hi. I have a 17 plate T6 with factory fitted Satnav. I’m struggling with a couple of bits per below and wondered if anyone can help. 1) is it possible to change the route colouring. I am colourblind and really struggle to see the route highlighted against the roads on the map. 2) I really...
  13. Wiltshirejay
    T6.1 Stereo upgrade to sat-nav possible ?
    Hello we’ve seen a 2020 Shuttle, the only thing that is holding us back is that it has no reversing camera and sat nav. Can I swap the attached photo unit out and put a sat nav one in ? Then run my own camera to the new unit ? Also rough prices please. Thank you
  14. Pauly
    T6 Radio Navigation System With Amplifier Wiring Diagram 2018
    Radio System Navigation System Circuit Diagram Covers discover media infotainment units fitted with factory amplifier and includes speakers, reverse camera, microphone and optional interface for mobile telephone and optional emergency call module You can find the standard discover media...
  15. Pauly
    T6 Radio Navigation Systems Wiring Diagram 2018
    Radio System Navigation System Circuit Diagram Covers discover media infotainment units and includes speakers, reverse camera, microphone and optional interface for mobile telephone and optional emergency call module VIP Membership is required to download this document
  16. Mike Dean
    Found 5C0035680 Discover Media with NAV and DAB.
    Does anyone have a 5C0035680 Discover Media with NAV and DAB they want to part with? Thanks :thumbsup:
  17. S
    Screen start up slow
    I have a new t6 kombi when I switch on the ignition the information screen / sat nav screen stays blank and can do for several minutes, whilst the dash board says starting navigation with the roundels turning line its loading something. What am I doing wrong ?
  18. Jago13
    T6.1 retrofit sat nav.
    Hi all, I’ve got a t6.1 highline, looking to do the digital dash conversion but I’ve been told it’s not possible unless you have the satnav/stereo option (forget what they’ve called the head unit) as this has a module installed to the glovebox and the head unit is simply a screen? I’m no...
  19. Oggsmith
    Now turn left
    After updating my satnav maps before a long drive this weekend I thought the Van would recognize the new bit of A14 in Cambridgeshire....
  20. Pethew
    App Connect activation
    Anyone got App connect to work in thier T6 ? I can see it and it asks for a code , but I’m told from the dealer that it isn’t possible to have the app connect unless it has been ordered from the factory. But why can I see it on the screen ..The Dealer seems lost on the subject ..
