seat belts
  1. P
    Found 3rd row seat belts
    Want the option to move my bench back so after 3rd row seat belts. The ones with the little hanger piece. Also on the hunt for 4 floor brackets. Cheers
  2. angelameaney
    Seatbelts on rear seating
    Hi, this might be a silly question but as I have zero knowledge of anything mechanical I’m going to ask anyway. We are converting our SWB T6 this spring. We are not wanting the traditional layout so have ruled out a rock n roll bed and RIB bed. We are looking at getting perhaps a U...
  3. P
    Found 3rd row seat belt hanger thingys....
    Does anybody have, or can point me in the direction of them seatbelt extension brackets you need when you move a bench seat from the 2nd to the 3rd row. Cheers
  4. K
    Found 2+1 Seat belts
    Has anybody got a pair of 2nd row seat belts for sale, for 2+1 seats, Many thanks
  5. P
    Found 2nd row seatbelts
    I am looking for the two outer second row seatbelts please. I have bought a bench seat and didn’t realise it has come from a third row position hence the belts are too short. Many thanks
  6. nomislotsirb
    Wanted Rear seat belt cover
    I don't suppose anyone has one of these available. It's the plastic cover to the drivers side rear seat belt in a kombi. Managed to break mine off when the Forty Winks mattress caught on it when folding.
  7. U
    Kombi - seatbelt length
    Hi all, Just wondering if anyone has had a similar experience - seatbelt seems rather small in my kombi and struggling to fit a car seat. Any recommendations? Note - seat doesn't have isofix unfortunately. Cheers
  8. M
    Single Wire under drivers seat
    Good morning all hope you are well. There is a singular wire under the drivers seat, it appears to go actually into the middle of the underside of the seat base. Does anyone happen to know what this is for, first guess would have been seatbelt warning but assumed it would have been routed...
  9. Kirkhamma
    Found T6.1 Rear Seatbelt
    Does anyone have a rear drivers side seatbelt for sale? Mine has stopped retracting / Retracts very slowly with help. Does anyone know if the O/S and N/S belts are the same? Thanks ☺️
  10. P
    Seat removal - electrics
    I thought I’d done all the research I needed, but apparently not. Today I’ve removed the seats in order to run my 12v feed to my leisure battery, and also the EHU wiring. There’s a load of wiring under the seat, which the forum has shown me how to ‘hide’. What I wasn’t expecting were the 4...
  11. F
    T6.1 Seatbelt warning problem
    Hi everyone. I am hoping some electrician wizzkid can help me. I have a 2009 T5 camper and have just bought a T6.1 to convert into a camper. I want to keep the drivers and passenger seats from the T5 and so have moved them into the T6. However there are no connectors on the T5 seats for the...
  12. Guy R
    Swivel base and occupancy sensor confusion
    Hi, I am in the process of converting my T6 .1 startline LWB transporter (2021) into a day van. While checking out conversion companies, I saw MSCraft's twin sliding base, which I like. I asked the guy who demonstrated the seat to us about the under-seat wiring and what, if any, coding...
  13. Bredenoord
    Second row seatbelt stuck on fully extended
    Hi, My boys fully extended the second row seatbelt and now it remains fully extended. Is there an easy way to fix this without dismantling everything. Also - If anybody has a diagram showing construction, would be helpful. Gerard
  14. secretK9agent
    Blue connector under passenger t6.1
    Investigating a rattle I found a connector with nothing going into it. Found another post about a blue connector and it being AdBlue related. This looks different and doesn't have anything plugged in. Any ideas?
  15. C
    For Sale T6 2018 Kombi Simora Rear Triple Folding Seat, Belts & Bulkhead with Window £800
    Hi all. I have a Kombi triple rear folding seat to include belts, plus a bulkhead with window for sale if anyone is interested. They are in good condition. I am in the Staffordshire Moorlands area. I am also going to the Bug Jam at Santa Pod next Saturday if you want to meet up. If you just...
  16. Richard Ferris
    Sold T6 Simora Kombi seats/belts/mat £950
    Hi Everyone, After several years of being the family vehicle, my Kombi is getting converted to (almost) full camper with a Variotech bed. Because of this I no longer have the need for the rear seats or ancillaries that go along with them. Included: 2+1 folding/removable Simora ISOFIX seats...
  17. Cuffy
    Wanted Rear seatbelt receiver - Plastic cover totally goosed.
    Due to some ham fisted eejit trying to lay the R&R bed flat for a tip run at the weekend, the said eejit couldn't get the bed to go down fully unless he adopted the belly flop routine. Once belly flop routine was carried out, there was a cracking sound which resulted in the plastic cover...
  18. T
    Looking to buy a T6 - advice re Minimum rear seatbelt length?
    Hello everyone - am looking to buy a used T6 LWB 17 reg and would LOVE some advice! we have two children 7 and 5. The van we’re looking at has two seat belts across the rear bench but not sure if they’re long enough? The dealer said they were 103cm fully extended. Any advice on what a standard...
  19. Danpearson1986
    Seat belt cover caps vw transporter t6
    Can anyone tell me the best place to get replacment seat belt cover caps.
  20. H
    Seatbelt recoiler unit rattle
    I have a transporter T6 & the passenger side seat belt (the lower unit that coils the belt up seems to developed a rattle inside . Has anybody had this issue?
