shock absorbers
  1. M
    For Sale T6.1 T32 Shock Absorbers £100 ono
    Selling my original shock absorbers from my T6.1 T32. They were on the vehicle for 4 years and have covered approximately 22k miles. Have removed them as have had coilovers installed. They are a used product so there is some wear and tear on them and there is some corrosion on the rear shock...
  2. T
    Spring Upgrade - Shocks too?
    Hi All. New to group and VW T6 SWB I have searched but have a specific question. If I want to upgrade a T28 to T30 spring on the rear of my van, do I also need to do the rear shocks ? And if I do the rear do I need to do the front also ? This is to give us a slight uplift as mindful of...
  3. Coly
    Easy way to change front Shocks
    Can I put spring compressors on front suspension, before starting, to simplify the removal of the front suspension unit. It seems a lot of effort to move hub assembly out of the way
  4. Smileysmile
    For Sale T6.1 T30 springs and shocks
    Here we have 4 x springs and 4 shocks from a 2023 T6.1 T30 with just 2.5k miles. £100 Reason for sale. Air suspension fitted. Removed with tlc. Cardiff area.
  5. Smileysmile
    For Sale T6.1 T30 coils/dampers
    2023 T6.1 T30 coils/shocks 2.5k miles only. Reason for sale. Replaced with air suspension. Professionally removed by garage. Near Cardiff. £80
  6. M
    Wanted T32 Sportline suspension
    I’m after T6-6.1 T32 sportline springs and shockers if possible. If anyone is upgrading there's let me know. Thanks
  7. Badjamin
    Found Bilstein shocks F4-22196712
    I need a new shock on nearside front. Am after a pair or single to replace it. Springs are fine apparently. Any advice or do I just buy one from bilstein direct - am assuming this is the way. https://www.bilstein-shocks.co.uk/products/replacement-damper-f4-22196712-uk?variant=45199417704700
  8. S
    Front shock absorber leak??
    Just putting new disc’s and pads on my 2020 6.1 Kombi 4 motion LWB and there seems to be a lot of oil around the shock on the N/S.. Is this normal amount or has the shock had its day?? (Please see pics) Cheers for any advice offered.
  9. Y
    Sold T6.1 Sportline shocks and springs
    T6.1 Sportline shocks and springs taken of my transporter at time of delivery. £300
  10. Tony Abbott
    B14 shock leaking
    In Oct 2022 i had Bilstein B14 Komfort adjustable coilover kit fitted to my van. Today then van has been diagnosed with a front passenger side leaking shock. 16 months after install and only 6000 miles on them. not happy to say the least. has this happened to anyone else with Bilstein and if...
  11. J
    Found T32 front shocks
    Hi Guys I’m after a pair of front shocks for my T6 as I’m looking sell my van in the new year so want to take the coil overs off. As close to birmingham as possible or posted to me. Thanks Jason
  12. T6 dork
    Wanted 1 n/s front strut/shocker for a T30 caravelle please
    as above please
  13. D
    Van rolls more after Shock absorbers changed
    vw t6 transporter just had rear shocks and springs changed but seems to roll a bit more on the back,is this normal
  14. A&A
    t32 hard suspension - pot hole avoidance
    I have had a few transporters in the past & a couple of LT's and the ride has been fine, but this van is such a hard ride I have to avoid potholes & cats eyes on every journey. Is it a T32 issue? I know there is a lot of advice here about suspension....but I am still confused. Any advice would...
  15. R
    Standard rear shock absorbers
    I have a 2017 Transporter SWB which I am lower by 40mm all round with lowering springs only. The rear shocks I want to replace with OEM ones. Looked around and can get delivery mileage ones at a good price. The thing that confuses me is part numbers. None genuine ones state they replace 7LA...
  16. Shaun P Bass
    Found T32 Rear Springs + Shocks...N/East
    Hi all. Looking for a set of T32 standard rear springs to boost up my back end on my 2017 T6. Maybe shocks also. Ideally located within 25 miles of TS13 (N.Yorks/East Cleveland) area...or poss post to me?.. Many Thanks Shaun..
  17. nelo
    Found T6 t32 2016 Front damper
    Well I just thought I would give this a go. I have just been to VW and as well as taking more of my money than i thought they should - they gave me a lovely video showing the front damper is leaking and I was wondering if any of you good people has a low mileage OEM front damper / drivers side...
  18. TW2904
    Sold Koni Shocks with H&R Lowering Springs
    T32 Koni Active Shocks with H&R 40mm lowering springs. Supplied and subsequently removed by Steve at CRS Performance. Covered less than 8k miles. These are a great upgrade and in full working order. They were reluctantly removed after 12 months as I wanted to go lower. Looking for £550...
  19. ma77y
    Found Caravelle executive dampers
    Hi all, looking for a set of dampers from a T30 caravelle executive for my 2018pv conversion. Newer the better must be reasonably priced. Intend to pair them up with a set of H&R 50mm springs. Happy to collect North West area
  20. CRS Performance
    Top shock mount modifications to get extra low .
    As most already know. We don’t like excessively dropped Vans because of the residual problems it causes , but I do get asked by some customers about the modified top mount , and the merits of this mod. Promoted by a few accessory companies . I thought it would be a good idea to expose this...
