slam vents
  1. D
    Water ingress.. from slam vents?
    Hi all. We have just purchased our first vw T6.1 and there is wet in the compartment at the back where the gas is stored. We have spoke to the garage that converted it and they are saying it’s from the spray off the tyre coming up through the vent. But the carpet is soaking. Surely this isn’t...
  2. K
    Puddle indoors!
    New to the forum and like loads started sound deadening and insulating the van. Full panel van atm. Just about to insulate the rear ns quarter and seen a few drips on outer skin (arrow) got a light out and seen a little puddle between rear arch and light cluster. Bit concerned as no idea how...
  3. batmeister
    Easy ventilation win
    Afternoon all, I know a lot of people (who sit around in the back of their van a lot) like to fit roof fans for ventilation and removing propane fumes etc. I was wondering if an easier option would be to fit fans in front of the outlet vents in the rear quarter panels. Has anyone tried this...
  4. I
    Anyone had any issues with the sliding-door not closing?
    Only had it happen twice, eventually after a few attempts it shuts.
  5. Andysmee
    Door slamming, bouncing and air pressure
    So, my driver's door rarely closes first time unless I slam it. The dreaded sounds-like-a-golf seal problem. But today, we wife was getting out of the van at the same time and the driver's door shut first time without slamming it. Hmm, so if the air pressure is relieved, the driver's door...
  6. S
    Slam vents - Use for ventilation?
    Hi all, So I have had an idea of using my slam vents to ventilate the rear of my can which will be a garage / kit store.I've managed to get a piece of hosepipe through the vent. I then plan on attaching a 12v fan and running this to extract air to help dry kit. The idea being that the negative...
  7. K
    Do I Need Slam Vents?
    Evening all, I'm looking to carpet my van tomorrow. Just taping the holes up and wondered if any are necessary for the slam vents? Or when people ply line do they add holes like the factory pannels to allow the air to pass? Cheers, Kev
  8. J
    Dust Entry
    When driving on dirt roads, how well dust proofed is the T6? You don’t have to wander too far afield in Oz to strike dust. Anyway, we like to go to out of the way places. I am planning in install additional seals on the front doors as the first mod. Thanks for your help and advice.
