sound deadening
  1. Beng
    For Sale Dodo mat insulation
    Left over from lining my van: Dodo Van Fleece Thermo Camper Insulation 10m DEADEZY ECOFILL (25mm thickness). Brand new unopened. Dodo Thermo Fleece EVO 10m (50mm thickness). Opened and used about 1m. Dodo Mat Thermo Liner Foil Foam 10m, opened and used about half £90 for the lot, collection...
  2. affetron
    Sold [eBay] Silent Coat Sound Deadening Mat - bulk pack - 34 sheets remaining. £35.00, no reserve.
    Auction listing. 2mm thick, self adhesive sound deadening mat. Description here: Silent Coat 2mm - 40 Sheet Pack Silent Coat is an EU competitor to DynaMat. Great stuff, have lined the entire inside of my LWB Transporter. This pack is opened and 6x sheets out of 40 have been used - 34x...
  3. B
    After sound deadening - which thermo liner?
    Hey all, I've added sound-deadening, Silentcoat 4 & 2 mm, just about everywhere and the difference is huge. Now it's time for the thermo layer / liner. Silentcoat Isolator or Dodo Thermo Liner or Dodo SuperLiner? Anybody had experience of the differences? My aim is to make the van as...
  4. M
    Ply flooring help
    Hi. Hoping someone can help with floor lining thicknesses. Im just about to line and ply my floor. I have got 7mm dodo deadn duo pro twin which from what i have read is best to lay over the top of floor batons rather than i between. I have a vanstyle deep step which says is suitable for 12mm or...
  5. jaybee
    Sound deadening with OEM speakers - worth it?
    Hi guy's, I'm going to sound deaden my doors, has anybody done this and kept the original speakers in,if so does it make much difference to the sound quality
  6. Beng
    Sold Dodo thermo liner insulation and dead matt pro etc sound deadening
    Left over from lining my van, seems i over ordered quite a bit! Dodo Thermo Liner v3 6mm 10m, (New unopened) Dodo – DEADN Mat – Hex – 20 Sheets (New unopened) Dead mat pro 27 sheets left out of 40 Dodo Thermo Liner v3 6mm 10m, over half left £200 for the lot, collection from Lymington...
  7. sipep
    Sound deaden floor channel - insulate or leave
    I wonder if you guys did anything for the bottom channel , Did you just leave it? There is some wax stuff and two holes. I thought I'd leave it in case it acts as a breather.
  8. S
    Sold Dodo Mat DEADN Hex 35 Sheets
    Dodo Mat DEADN Hex 35 Sheets Slightly (massively) over estimated how many of these I would need for doing up my van. Looking for £40 on collection in London, E17 (preferable) or can add postage price if wanted. -
  9. T6ChrisO
    For Sale Dodo Sound Proofing & Liner
    Is there a market for left over Dodo products? I have three sheets of DEADN which I don’t want anything for BUT I have loads of the thermal liner left. Not sure what would be a fair price to be honest so happy for someone to offer what they think it’s worth. Not unrolled it to measure but...
  10. sipep
    Sound deadening barn doors? Remove lock mechanism?
    Anyone sound deadened their barn doors? Did you remove all the lock mechanism?
  11. tgw
    Sold 2016 T30 Startline LWB P/V. £12,500
    Up for sale my long wheelbase Volkswagen Transporter T6. Runs very smoothly sad to be getting rid of it. There's a minor bit of rust on the lower side panel (shown in pictures), it's easily touch-upable. The last full service was done in November, and new tires were fitted in January. I'll dig...
  12. B
    Silent Coat 2mm , 3mm or 4mm sound deadening
    Hi , 1st post so hopefully it's in the correct place. Apologies if its been asked before but I can't see anything regarding the different thickness of Silent Coat sound deadening sheets . From what I can see most people opt for the 2mm version which is foil backed - the 4mm version may be to...
  13. B
    Silentcoat vs Noise Killer
    Has anyone got experience of using Noise Killers kit as opposed to going the full SilentCoat route? The NK kit seems quite thorough but as would a full lining of SC. This is the NK kit… VW T6 Soundproofing Kit - NK Group Versus using this is 2mm or 4mm…...
  14. ToddiesT6
    Sold Dodo deadening
    I well over ordered on the Dodo deadening mating sheets when I started converting my van & have around 60x sheets (3boxes) left over. Happy to split packs & post out what you need (at cost) or offer the lot for collection. Price depends on how many sheets you want- so PM me.
  15. Carlwaynie
    Sound deadening - everywhere or select areas?
    Hi all… looking at utube and this forum for some clarity ,will be having a new T6.1 at some point in the near future and even though I wont be using as a camper I will still want it sound deadding and carpeted in conjunction with an upgrade to the audio system, now when searching this topic I...
  16. M
    Best to remove bulkhead on new van for sound deadening or not?
    Morning I’ll be picking up my new panel van soon and will then start on sound deadening the cab and the rear. I’m having an extended bulkhead fitted - my question is, is it better to not get the dealer to fit that bulkhead before sound deadening or is it no problem to sound deaden with it in...
  17. Carnut2chris
    Soundproofing after build
    My van is fully built but I'm wondering is there any more i can do to soundproof the van further? I know i need to get around to soundproofing the front doors and cab floor at some point but should i be looking at Dodomat in the backs of cupboards draws etc, Cheers Chris
  18. dave_b
    Will I have to remove deadening to fit floor?
    I have applied sound deadening to the floor of my Kombi. when I convert the van to a camper, will I have to remove the deadening to install a floor?
  19. SofaKing
    Remove Rear Side Panel -sliding Door
    anyone that can describe how to remove panel AS shown in picture? Appreciated!
  20. jonzi
    Self fitting speakers and sound deadening.
    Hi All I plan on upgrading the speakers in my T6.1 to the Focal ones. At the same time I'll add some sound deadening. Is there any thing else I should do whilst the door cards are off? I planned on buying: Silent Coat 2mm Focal IS VW 165 I was going to fit the silent coat to the inside of...
