sportscraft swivel
  1. Wrigles
    Sold Single Swivel Base & Handbrake Lowering Bracket £50
    Sportscraft Single Swivel Base T5/T6 (new unfitted) and used handbrake lowering bracket.. I don’t have the fixing bolts for the swivel.. but sure these can be found.. £50 the pair.. collected from Manchester.
  2. M
    Sold Sportscraft swivel bases 1 sold 1 left
    Never been fitted. £135.00 each or both for £250.00. Collection preferred from Pontefract
  3. P
    Sold Sportscraft Swivel Seat Base - £100
    I have a Sportscraft Swivel base for sale. Part number 3348002. Perfect working order - removed from the van I bought back in February after I needed an extra centimetre of height after Ireplaced the AGM battery with lithium... Price £100. Collection from South Ayrshire in Scotland or I...
  4. Sturge
    Sold Sportscraft Swivel Seat base
    I have a unused Sportscraft Swivel base for sale. Never got round to fitting it! Part number 3348002. Price £100 (new they are £150). Happy to send it by courier at cost or welcome to pick up - near Pulborough in West Sussex.
  5. IestynD
    Found Single seat swivel base - Sportcraft
    Hi all, As per the title, does anyone have a single seat base swivel. Ideally SportCraft. Happy to pay the going rate. Thank You
  6. 3crispies
    Sold Sportcraft swivel
    Passenger swivel for battery £80 Located Cambs
  7. 3crispies
    Sold Kombi Bulkhead
    Motexion bulkhead. £150 Collect Cambs or collect dubs@castle (if prepaid) Funky leisure C channel awning rails, have one for both sides (driver side pre drilled for reversal) £40 Will have a passenger seat swivel but still fitted until weekend pretty sure its sportscraft £80...
  8. J
    Sportscraft Seat (yet another swivel thread)
    Hi All, just fitted my passenger side, leisure battery, swivel seat. If I slide the seat back, the seat cross bar the (part of mechanism that slides it back and forth) hits the central nut on the swivel. Has anyone else had this? Am I missing something or do I have to fit a spacer to give it...
  9. T
    Sold Sportscraft passenger swivel seat - new (& unused)
    Selling my swivel as I need the one to sit on top of leisure batteries! Taken out of the box, tried fitting, now back in the box! collection from Southampton or happy to support courier if you’d like to arrange (c.18kg in weight). Price £115 thanks for looking dan
  10. M
    Sold Sportscraft drivers swivel seat base
    Removed from van a little while ago ( hence a layer of dust ) but in fully working order. Was on drivers side, not sure if it works on single passenger seat too. These are around £150 so asking £75. Collection preferred from Pontefract area but willing to meet up within reason. Taking a trip to...
  11. I
    VW T6 Sportscraft handbrake lowering kit
    Hi All, Needing some help. Has anyone fitted a sportscraft hand brake lowering kit? I have attached the bracket to the handbrake but when I put it back on the rear bolt fowls on the seat base. Am I doing something stupid? I have taken a photo. It won’t go in because of that rear bolt Any...
  12. Jimmi
    Seat swivels and factory leisure battery
    Is it possible to fit a seat swivel with the factory leisure battery under the passenger captain seat? It looks like it’s just slight higher than the base
  13. Ethan Andrews
    Handbrake move from VW to Sportskraft
    I want to replace my VW drivers seat base with a Sportskraft swivel base. The passenger seat was easy. I can see predrilled bolt holes in the new base. And obviously it has come with a handbrake fitting kit. But in principle. What is involved to move than handbrake. The OEM seat base I...
  14. Sturge
    Leisure battery physical size under Sportscraft Swivel
    Hi. I’ve just fitted a creek charger from travel volts which is all good. I have the factory battery which seems to be a VW agm 75ah battery. It seems to sit just a few mm higher than I need for my sportcraft swivel that I’m trying to fit. Is there a smaller better battery that would fit in the...
  15. B
    Sportscraft Seat Swivel Question
    I have narrowed my search of swivels for my two front (single) seats. Unfortunately Kiravans are out of stock of a matching pair, so I am looking to buy the Sportcraft swivels. My question is can the Sportcraft driver seat swivel be used without having to cut plastic trim or lower the...
  16. teamfly
    Battery For Under Single Seat With Sportcraft Swivel
    Can anyone tell me if a 190 height battery will clear under a single passenger seat with a sportscraft swivel on ? Any recommendations for a battery appreciated .
  17. 5teve
    Sold Sportscraft Seat Swivel
    Sportscraft seat swivel - nut on top suitable for leisure battery. 5 months old - excellent condition. I’m near Folkestone Kent. Happy to deliver locally or meet somewhere
  18. T
    Passenger Single Swivel
    Morning I want to put a swivel on my single passenger seat only (driver is staying where it is). I've narrowed it down to either the Kiravans offset (out of stock) or the Sportscraft (plenty in stock). Does anyone have the Sportscraft one? If so, when you swivel it, do you need to play around...
  19. Andy Power
    Is This Swivel Seat Any Good?
    Swivel Seat Base (Passenger) VW T5 2003–2015 VW T6 - J18044 Has anyone bought this? If so what’s it like? I’m wanting to fit to my T6 passenger side.
  20. Fish
    1 Sportscraft swivel with handbrake lowering kit.
