starter motor
  1. C
    Starter disengaging too soon
    Hi guys Got an issue with my 2019 t6 Cxgb 102bhp The starter is disengaging too early causing it not to start 50% of the time, sometimes takes 4 or 5 goes to get it to start and when it does start it has a slight dip in rpm as soon as it starts. Runs and drives fine no issues once it’s...
  2. F
    Replace starter motor
    Hi! I'm new to this forum. I live in Sweden and own a 2018 T6 2.0 tdi DSG. I need to replace the starter motor. Does anyone have some useful tips/tricks. Looks like I have to do it from above? Do I need to drain the coolant expanaion tank? It looks like there is a hose at the bottom of the...
  3. P
    Intermittent Long Crank (randomly once/twice a day)
    Hi guys I hope you’re well. I’ve done a lot of reading up on the forum, but can’t seem to find a definitive answer on this, so wondering if anyone could help me diagnose an intermittent issue I’ve been experiencing please. The van starts fine in the morning and 90% of the time during the...
  4. T
    Cranking longer before starting
    Every now and then my 2019 150hp T6 is cranks for much longer than normal before it starts, it done it today after being parked for several hours. It doesn’t do it that often. The battery is new and good. Any common issues people are aware of before I speak to VW?
  5. M
    Starter Won't Turn Around after turning Key - T6 Starter motor
    Hi Everyone, My name is Manlong from the Netherlands And I have a huge problem with a T6 2017 van. My neighbor bought this van with the intention so make it work and sell it. Because he doesn’t has time so I wanted to help him so I can get my van earlier. The van was a ex police van that had...
  6. H
    T6 not turning over [Resolved]
    Hi, I'm new to the forum and also new to a T6 (only had mine a couple of months). Everything was fine with the van until last Wednesday when I went to drive home the van wouldn't even turn over. The engine light is on permanently and as soon as I try and turn the van over the glow plugs warming...
  7. Shortbread69
    Engine startup issue [Resolved]
    All, is this start sequence ok? A video is worth a 1000 words. Hope you can see it below. I have to say this only happens occasionally, but I don't like it! :) I release the key on initial cranking then the engine takes a couple of seconds to get past the cranking on its own... The rest of...
  8. M
    T6 Not starting - advice needed from starter/ignition folk.
    Guys and Gals Another one for you. 2016 T6 starting issue. Yesterday I tried to start my other T6 and I think I've got a problem. I dont use this van much as I'm working on it gradually - Had a new battery 4 months ago and started fine - the Cold weather and infrequent starting has given the...
  9. F2JON
    Starting issues [Resolved]
    ok so I’m having issues with my van starting, I took it into mid Vw three weeks ago they put a new battery on and did a diagnostic check which bought up an alternator fault, but they wasn’t sure, so I had the van back, I hardly use the van at all but haven’t had any issues with starting till...
