tailgate lock
  1. Skyliner33
    Unlocking tailgate on fob.
    I’ve just noticed that my tailgate doesn’t unlock on the middle button of either key fob. I’m sure it used to do. I can’t find any setting in the head unit or reference in owners manual. Any ideas? T6.1 for reference. Tailgate will unlock with the open doors button. Anyone can test their fob...
  2. R
    Tailgate lock actuator
    My 2018 T6 rear tailgate suddenly unlatched and wouldn't open from outside or inside. So here's what I did as temp and then permanent fix. Temp fix - on inside just above the latch in centre of tailgate is a rubber grommet. Remove to expose latch mechanism. You will see the latch bar. Pull this...
  3. F
    Tailgate latch no longer tight
    I've had a T6.1 for a couple of years and the tailgate has always closed fine. A few weeks back it stated misbehaving. This is not a "soft close" or electric tailgate - just the old fashioned slam it down type! When I close it now, it kind of bounces back slightly and doesn't close tight. When...
  4. Y
    Tailgate Locking Problem.
    Hi All, I've seen a few posts on here re-tailgate locking issues but unfortunately none that have helped with my issue. The tailgate lock on my 2017 T6 (T32) seems to be "electrically" locked and I cannot open it with either the key fob, or either of the exterior or interior releases. I managed...
  5. J
    Tailgate Lock Has Died - Open It From Inside ??
    Help please? I have a Transporter Kombi T6 (March 2018). The tailgate lock has stopped working. When I pull the tailgate handle I hear a short electronic buzz, but it doesn't unlock. Couple of questions: 1) Is there a way of opening the tailgate mechanically from the inside (bypassing the...
