terminal 15
  1. 8balladdict
    Rear tails on as DRL's
    Hi all, So I did all the basic coding last night (Alarm lock beep, needle sweep, digital speed thingy, seat belt warning etc etc). I then went and ordered some LED tail lights so wondered if anyone has set them to be on with the DRL's? I didn't see the option while looking through the coding...
  2. Ewan
    DRLs turn OFF with indicator on
    Hi i am looking for Byte 23 bit 7 - when ticked DRL/DRLs turn OFF when blinker or emergency lights are activated on VCDS but i cannot find it anymore. I have the current update but it is not there, has this setting moved or been removed Cheers Ewan
  3. Salty Spuds
    Yet Another Ignition Feed Question, This Time With Is1 Interface
    I’m in the process of swapping my lead acid battery for a Lithium & i need to pick up an ignition feed to trigger the Sterling B2B charger. I have the IS1 interface under the passenger seat, the one with the Purple/Grey/Yellow plugs. There are a couple of pins that look as though they might do...
  4. walnuts
    Lighting Madness
    I've been suffering from some really weird problems with my lights, details below, anyone got any idea what the hell is going here? I'll try and keep it short.... So a few weeks ago I noticed that my interior lights had packed up, thanks to the info here I was able to find the relevant fuse and...
