third brake light
  1. O
    Sold T6 Rear High Level Brake Light – Barn Door
    Removed from T6 (2018). Great condition. £30 plus P&P (pair only).
  2. PrinceAdam1978
    T6 - 3rd Brake Light working, main Brake Lights not working [Resolved]
    Hey guys, Need some info or inspiration from the hive-mind. My mate was following me back and noticed the main brakes not illuminating. The High Level is fine. All fuses in the fuse box to the lower right of the glove box are all sound. All bulbs are perfect with no broken filament. Was...
  3. Caston82
    Third Brake Light - same T5 to T6?
    Hi i recently bought a high level brake light reversing camera for a tailgate VW T6. It was advertised as a suitable for a T5 and T6, took it to my local installer who said it doesn’t fit and only fits a T5. Is this likely to be the case?
  4. J19WMK
    Rear 3rd Brake Light Install (Smoked)
    Quick swap out after being chipped.
  5. N
    Water leak in tailgate
    A few days ago I opened the tailgate to hear water sloshing round inside. When I checked the tailgate had quite a bit of water pooled in the bottom. I had rained the day before and I had just washed it. I thought I would test it out today whilst washing. Tested round the window seal...
  6. B
    Barn door leaking at top
    Hi, I have a water leaking into the van from the top centre of the barn doors. Both seals have been replaced but the leak still persists. I’m suspecting it could be a door alignment issue and a garage have advised I need to go to a body shop. Just wondering if anyone has had a similar issue...
  7. Paynewright
    Barn door brake light quality?
    Hi My 2018 barn door van has now cracked both of its high level brake lights. First one (drivers side - door rarely used) changed a few months ago. Passenger side one has also now cracked through the red outer plastic lens! Anyone else had this? Out of warranty but feel like sending back to VW...
  8. T
    Tailgate third brake light vendor
    Got a litre of so of water in the rear tailgate. Suspect it's coming in through the cracked high-level break light (seems like a common problem). Need to replace it but cannot find anywhere who sells them for a T6. I can find loads for T5 (apparently it's a different fitting for a T6), and loads...
  9. M
    Sold Smoked High Level Brake Light
    Brand New T6 Smoked High Level Brake Light. I brought this in error and held onto it before realising that I'd ordered the wrong one. Its as new, complete with protective film on the front, £45 posted
  10. 9
    [Guide] Reversing Camera OEM Cable Routing
    Hi, Currently installing a pioneer ND-BC8 reversing camera to my T6 Transporter, Looking for advise on picking up a reversing feed in the cab area Regards Jon
  11. cgtmiles
    Sold Smoked third brake light NEW
    Unused travelin lite smoked third brake light for sale. As new condition as I decided against fitting after changing my plans for my rear lights. £45 delivered. See travelin lite for more details and better photos
  12. RedUn
    Found 3rd Brake Light Tailgate
    After failing to take mine out in one piece does anyone have a spare knocking round? Would go dealers but they are closed... Cheers Rich
  13. goldeneye243
    Third Brake Light with Reversing Camera
    Just wondering how tricky it is to fit the OEM reversing camera in a tailgate kombi? I'm going to have it converted into a camper fairly soon - Is it better to wait until then, or go ahead and do it? Also any opinions on whether it is worthwhile doing it or if the reversing sensors are good...
  14. Para J
    T6 Tailgate 3rd Brake Light
    Hi all anyone had trouble with their high line brake light. Mine the seal has gone and the light fell out. Para J
  15. eauto
    Water In Bottom Of Tailgate
    Today on closing the tailgate I heard water sloshing around, on investigation I found two rubber bungs on the lower edge of the tailgate, when I removed these about a litre of water drained out. Has anyone else had this problem, and should I leave the bungs out so the water can drain?
  16. Markymark
    Water pouring out of tailgate
    havent used our van for a few weeks. Opened the rear tailgate today and water poured out from the door card. Not just a drip or two but litres of it! Can’t think it is from the conversion as they haven’t made any additional holes in the door in the outside. Perhaps the rear window is leaking or...
  17. R
    Brake light flashing and Hazzard warning lights under braking
    Hi Guys its possible to tick boxes in 09 Central electronics to make the brake light flash under hard ABS braking and the hazard lights come on when you stop (they go off again when you move away) good on motorway I can post a scan later if needed van is not here right now but I'm sure some...
  18. T6dder
    Fitted my LED Tail-Lights - Smoked
    Thought I would share a photo of my new LED tail lights I fitted a few weeks back. These are the smoked / tinted models which look great on my Blackberry T6. They blend into the body colour perfectly. I have to also say a big thanks to @Pauly for writing some great instructions on fitting...
