Hi, I'm going to install a new EGR Valve and wondered if anyone could help me with the toque settings particularly at the exhaust end of the EGR pipe... I've tried to download a manual from the downloads area but no luck with that ...could anyone help. Would actually be grateful of any advice...
I am looking at replacing my clutch and DMF on my van 150ps 6sp CXHA on the weekend, I have managed to find the flywheel torque settings though the downloads in the VIP members area but unable to find the procedure for the clutch replacement.
If anyone could point me in the right direction or...
Hi all, it would appear that VW have changed the torque setting for the aux tensioner bolt from 50Nm plus 90deg to 50Nm plus 180degrees.
See below from member SimonS today.
Can someone confirm the tensioner torque settings please, I have found 50NM and 180 deg and 90 deg.
I assume they changed...
My first post, apologies it's a bit of boring one. I've got a horrible creaking sound coming from my T6 drivers seat base area so I had a go at checking as many fixings as I could access and in the process managed to shear one particular fixing. I'm looking to purchase a replacement...
Hello
First time poster!!
I have a T6.1 Caravelle (2019, CXFA) with a CBI brake system on the front brakes (PR number 2E3, disc diameter 308mm).
I am going to change the pads and disks myself but I cannot find the torque values for a front CBI braking system. Does anyone have the torque...
Any Vossen users out there have any idea on the bolt torque setting to use? 140nm just doesn't feel enough (read somewhere), just worried about over cranking em.
Cheers.
Hi can any one help me or point me in the right direction looking for torque settings for Egr cooler and pipes ect and rear and front brake caliper discs ect thanks
Can anyone confirm the torque setting for the main crankshaft pulley bolt. On a 2016 180bhp engine, cfca engine code.
Was replacing the crankshaft seal while doing the timing belt. The manual I have says 180nm + 135° which is fecking tight!! Wanted to check it wasn't an error.... Also not sure...
I've just discovered that the top roller part on my sliding door on my T6 California Beach is loose and rattling about!
Could anyone tell me what torque the two bolts holding the upper roller guide to the door should be torqued to?
The bolt in question is marked with the dot in the...
Hi everyone
Fitting solow coilovers next week and have been gathering the required tools and getting as much info as I can but when it comes to torquing up the front pinch bolts (t32) and both the upper and lower rear damper bolts I keep coming across different figures everywhere I look. Even...
hi everyone, hope your all well :D
i'm changing my aux belt, tensioner and idler as a precaution as there's a slight noise from them that i don't like... :eek:
what's the book torque values please for;
bolt holding tensioner to engine block?
and
idler pulley bolt?
the other idler comes...
In the process of replacing the cab door seal and have started to take the B pillar trim off.
Any ideas what torque setting the bolt needs to go when fitting it all back?
Thanks all.
Hello all,
I'm in prices of changing the discs and pads and have gone to tighten the bolt to secure the disc to the hub. In a thread on the forum it says 20nm. However my torque wrench only goes as low as 28nm. Will the extra .8nm be ok if I tighten it to 28nm?
Fitted aftermarket wheels to my T6 and confused what torque is needed for the wheel bolts.
The oem wheels and ball seat bolts were tightened to 180nm which I understand is vw spec.
However the aftermarket wheels are using 60 degree tapered / conical wheel bolts which the tyre fitter suggested...
Gents
Does anyone know the torque setting for the clamps that hold in the injectors, T28 T6 late 2015. When I bought the van the rocker cover was damaged and to change the rocker cover you have to remove the injectors.
Cheers Baz
Diagrams/Listing For All Earth Point Locations
Includes earth point reference number and relative torque values
Below is a sample image of part of the document
Please see the linked wiring diagram for more info on equipment earthing
