Looking for a bit of advice please.
I’ve just had a ORIS Fix4Bike detachable tow bar installed. Does anyone have experience with these?
I’m wondering if I need to get the ‘standard’ removable tow bar to use a bike carrier without Fix4Bike? I’m about to push the button on an Atera DL3 and...
Morning,
I am looking at getting a towbar fitted to our 2022 T6.1 VW Van. The plan being to get a towbar bike rack that will be big enough to take a couple of adult bikes and two childrens bikes.
Doing some research on the forum I can see that the best option would be a Altera Strada. The...
VW Additional Fusebox 000 055 212A for towbar, but could be used as an extra fuse box if fitting more 12v components. 12V ignition live under the seats perhaps?
Was bought to fit a tow bar, but already had the wiring required from factory.
Looking for £35 posted
As above; has anyone installed a 2” receiver hitch on their van?
Looking at this as an option for hitch mounted vertical bike rack. Used the tailgate mounted one this summer properly for the first time and frankly it’s fairly subpar.
Keen to see pics if you’ve got a 2” receiver, and get...
I have a t6.1 2021 dsg and it does not have trailer prep . I’m buying a wedtfailia tow bar and electrics kit and would like to know the cheapest software kit to buy for me to plug in an activate the tow bar / be able to read codes etc in the future with the van.
I have an iPad , and...
I fitted a genuine westfalia detachable towbar and wiring kit to my 2022 6.1 when i first got it, never really used the towbar until recently and now found that disconnecting the trailer while the van is locked does not set off the alarm !
The trailer in question is a large modern car...
Just had my tow bar fitted so have the rear bumper reinforcement bar available, T6.
The part is from my vehicle which is a 2017 Kombi T6. Looks dirty but it’s not rusty
I am in Northampton . Buyer collects. £80.
I've just put on our Tow-Trust removable towbar and the key is now stuck in the lock and I can't remove the towbar. I can only slightly move the release lever.
Any suggestions? I've tried WD40
Evening all
So I'm looking for some advice, just had my T6 lowered and while in the garage I asked them to remove the towbar which is a fixed towbar, as I want to do a rear bumper upgrade and have no use for the towbar.
However they phoned to say couldn't remove it till I got a new rear...
Westfalia detachable towbar ball
After having my van lowered 80mm plus my caravan no longer sat level when towing using the factory supplied Westfalia tow ball. After much research and asking sellers to supply measurements I bought this ball which sat higher and made the caravan sit level. I...
