tow bar self fit
  1. Ads_Essex
    T6.1 Westfalia Towbar Fitting Instructions 5
    Westfalia Towbar Fitting Instructions No. 322074300: electric wiring kit for towbars 13 pin / 12v
  2. Ads_Essex
    T6 PF Jones Towbar Fitting Instructions 1
    PF Jones Towbar Fitting Instructions No. 19270522: electric wiring kit for towbars 7 pin / 12v / ISO 1724
  3. Ads_Essex
    T6.1 PF Jones Towbar Fitting Instructions 1
    PF Jones Towbar Fitting Instructions No. 29270547: electric wiring kit for towbars 13 pin / 12v / ISO 11446
  4. W
    PF Jones Universal Towbar Wiring Kit - 1D7 Towbar Prep
    Morning all. After a chat with my local independent vw garage as to whether or not my van is towbar prepared. They checked my serial number codes and reckoned it is. So, ordered a Tow Trust unit from PF Jones as Westfalia units out of stock since February with the towbar prep loom. This has...
  5. Jon Sealey
    Hi all, it’s probably been discussed a million times but I can’t find a definitive answer. I’m wanting to add the westfalia towbar to my 21 plate t6.1 which according to the build sheet it has trailer prep from factory. So that ticks the easy box as such. The question is around the removed...
  6. G
    Found wanted tow bar for my vw t6 2016 any cheap ones out there please
    looking for a decent tow bar , some prices I've seen are a tad high lol vw t6 2016 i can fit myself located blackpool
  7. R
    Has anyone fitted a genuine Towbar wiring kit to a T6.1 without trailer prep?
    I've just fit the Westfalia towbar to my new 72 plate T28 SWB panel van yesterday and have a vehicle specific wring kit which i haven't fit yet but I'm thinking of getting a genuine kit if one is available? Does anyone have any experience of fitting the genuine kit? Is it fairly straight...
  8. K
    Tow bar electrics - replace aftermarket unit with OEM?
    Hi got a t6 with a after market relay box fitted in the rear of the van I’ve seen genuine loom for sale dose any one know if it will be easy to install with out any instructions I would like to get rid of the after market box wired of the bk lights also I’ve got a strange fault code (trailer...
  9. Dellmassive
    Tow-Trust detachable Towbar - "TVW9VK" kit & Wire kit -- How I Done It --
    Tow-Trust detachable Towbar - "TVW9VK" kit & Wire kit -- How I Done It -- Here we go, following on from this thread . . . - Towbar recommendations please i though it was time i finaly got around to doing it myself. . . it started with a quote from the main dealers . . . and the...
  10. Dai_namik
    T6 Towbar Fitting - bumper supports?
    Hi all, I want to fit a factory westfalia detachable towbar, I have a 67 plate lwb kombi with towbar prep, can anyone advise me on what exactly I will need to do it myself, I've read a little on it and seen posts on foam pieces for strengthening the bumper after removing the crash bar etc, but...
  11. J
    Westfalia detachable tow-bar self-fit [Guide]
    So I decided to purchase the Westfalia detachable tow bar this week and set about fitting it. I bought the towbar and dedicated electrics from PF Jones. I've fitted it to a 2017 T6 and taken a few photos which may help someone. Not a bad job, but I'm fortunate to have ramps at our garage. It's a...
  12. M
    Tow-bar coding on OBDEleven
    Fitted my own towbar and have obdeleven but can't seem to find the required coding steps. Can anyone help?
  13. Simon66
    Tow bar electrical installation
    Hello all, My panel van that is currently away being converted has a tow bar but no electrical connection for it. The plan is to get it wired in at a later date but I'm now wondering where the electrics for the tow bar would plug into the rest of the van and if they'll be accessible after the...
  14. C
    Westfalia TowBar fit
    has everyone gone for the full vw wiring loom for the westfalia or the cheaper option which isn’t coded. What’s the differences please. Had just a standard fixed on my last t5 which wasn’t coded and was fine. Going on a T6 Kombi to pull a caravan. Cheers
  15. Paynewright
    Towbar Electrics again!
    Hi, I fitted my towbar ages ago (easy bit!) and have just ordered the 13 pin Westfalia electrics kit to finish off the job. This is a two part kit - firstly, the main 13 pin loom and secondly, the separate ignition switched live loom for the 12v auxiliary (fridge etc in the trailer). This...
  16. OllieGBR
    VCDS tow bar question
    I fitted my own tow bar and VW wanted too much money to program it. It's the Westfalia with OEM electrics from PF Jones. I'm just about to receive my VCDS unit and want to make sure that I don't need the tow bar prep to enable the features via the programming. I hate the reversing sensors...
  17. Stelow7
    Tow Bar Coding
    I fitted a towbar with pf Jones electrics I was wondering what coding I need to do. I have vcds
  18. Pau1GTI
    PFJones Towbar fit
    Guys, I've recently fitted a pf Jones vehicle specific wiring kit for my T6 tow bar. Just been told by the dealer you need a vw wiring loom only to get the parking sensors to disable automatically. Anyone know if this is true? Cheers Paul
  19. Joblue
    Where to buy towbar and at what price? DIY
    I need to get a tow bar fitted to tow a small trailer, I have had a few quotes but just wondered what you guys might suggest as a reasonable price. Also should I get a removable or fixed hitch and will any electric work affect my warranty?
  20. H
    Towbar Preparation Question
    Hi, I am specking my T6 and have opted for the towbar prep. I am a little confused as to exactly what VW provide here and wondered if anyone has specified this on a new build before and can clarify please? In addition to the actual mounting points for the towbar and coding, I am confused if...
