tow bar socket
  1. Ads_Essex
    T6.1 Westfalia Towbar Fitting Instructions 5
    Westfalia Towbar Fitting Instructions No. 322074300: electric wiring kit for towbars 13 pin / 12v
  2. Ads_Essex
    T6 PF Jones Towbar Fitting Instructions 1
    PF Jones Towbar Fitting Instructions No. 19270522: electric wiring kit for towbars 7 pin / 12v / ISO 1724
  3. Ads_Essex
    T6.1 PF Jones Towbar Fitting Instructions 1
    PF Jones Towbar Fitting Instructions No. 29270547: electric wiring kit for towbars 13 pin / 12v / ISO 11446
  4. B
    [Resolved] LHS trailer indicator not working
    Hi all, have searched thoroughly but cannot find the answer so hopefully someone knows My left hand side trailer indicator does not work. I have a 2019 Caravelle with a factory fitted towbar and 13 pin socket. I have tested the trailer and there is continuity on the indicator, I have checked...
  5. G
    LED trailer tail-lights
    I have VW trailer wiring on towbar and led lights on boat trailer. The warning symbol comes on with "check left tail light". I know this is triggered by led lights and vw sell an adapter to rectify , but it is quite expensive. As all my lights are working correctly on van and trailer when...
  6. T
    Tow electrics issues…. No left hand indicator or brake lights [Resolved]
    Hi all, I’ve came to use my (7 pin) trailer for the first time in a while and I’ve got a right hand indicator and side lights but no left hand indicator or brake lights. It was fitted and coded by me using a genuine loom and has been fine for 4 years until now. I have, however, fitted a new...
  7. G
    Identifying tow bar
    Hi, I have a detachable tow bar on my T6 unfortunately I do not have the detachable piece and need to purchase another. Can anyone help with identifying the brand as I can not find any brand markings. Thanks
  8. roadtripper
    Trailer Socket 12v EHU - How I've Done It
    So following some experiments over here I thought I'd write up making an adaptor to connect a charger to a 13 pin trailer socket. Caveat: This is presented as info for what worked for me, make your own judgement about if it works for you :thumbsup: What is this? In a fully wired 13 pin...
  9. roadtripper
    T6.1 OEM Towing Socket behaviour
    So today I have been tinkering with my towing socket and thought this might be useful info in a post for others. My van is a MY21 T6.1 Caravelle with full towing electrics from factory. (Edited to add mine is a single battery system) This is my experimental 13 pin plug. There are 4 grain of...
  10. Salty Spuds
    Trailer Pin9 Supply
    I've searched the forums & downloads section but to no avail, so I'll ask the collective. I have a camper conversion based on a panel van with factory fitted towbar & electrics. AFAIK, Pin9 in the towbar 13pin socket is a permanent 12v feed from the vehicle battery. If I'd had a factory 2nd...
  11. M
    Side Lights /fuse Issues.
    Hi I’ve just joined as I have a problem with my 2018 T6 van. I had a towbar fitted and all was well whilst I towed a trailer with led lights but towing with normal bulbs appears to have overloaded a fuse. It would appear that they’ve wired both left and right hand trailer lights together at...
  12. K
    Tow Bar Electrics
    I'm going to look at a van at the weekend that has a tow bar fitted but it only has a 7 pin socket has anyone chaneged the seven in to 13 pin which i nees for my caravan and how easy is it to do is it just a matter of connecting a loom into the existing plugs in the van loom Regards
  13. C
    Westfalia TowBar fit
    has everyone gone for the full vw wiring loom for the westfalia or the cheaper option which isn’t coded. What’s the differences please. Had just a standard fixed on my last t5 which wasn’t coded and was fine. Going on a T6 Kombi to pull a caravan. Cheers
  14. D
    New T6 Towbar Reverse Light Connection.
    Hi all, I have got a T6 lwb for work and started to fit things to help with day to day work. It has come with the 13pin tow bar. So I have made a led light with magnetic base to use as a work light and works excellent and just plugs into the towbar connected to the permanent 12v. I also made a...
  15. Stripy
    13 pin towing socket
    I had a tow bar fitted at vw when I bought my t6 but it was fitted by an outside firm, I have now found that the pin no 10 (fridge ign live) is not working. Would it be ok to put a link wire from pin 9 perm live across to pin 10 , I know that if the fridge is switched on 12v and left on...
  16. G
    Towbar electrics retrofit: towing / charging / braking
    when a towbar is retro fitted with the 13 pin socket with factory rear parking sensors and camera highline alarm. Regarding the charging of the onboard battery in the Caravan. Does the T6 have to have a fancy CTEK split charger or does the battery charging go through the caravans onboard...
  17. H
    Towbar probs
    Hi guys, had a towbar fitted this week, a bossal removeable one with a right connections wiring kit. Got the van back and now the intermittent rain wipers won't work and also where the cruise control display is there is now an exclamation mark and cruise won't work. I can't take it back...
  18. L
    VW towbar wiring kit DIY issues.
    help required please! IM GOING DEMENTED . Has anyone fitted a genuine VW 13 pin wiring kit to a T6 Kombi? In the wiring kit instructions it tells you to terminate some of the wires in the fusebox located under the passenger seat. i dont have a fusebox under the passenger seat! i have the cage...
