transporter t6
  1. MrWigg
    For Sale 2016 T6 FOR SALE; SWB 2.0 TDi T28 150PS Startline £29,995 Reduced
    Model: TRANSPORTER T28 TDI P/V STARTLINE BMT, T6, 2.0 TDI, SWB, BARN DOOR. I love this van, but a change in circumstances means it deserves a good home with someone who can use it to its potential. I will listen to sensible offers. Please feel free to contact me. Thanks. Date of Reg...
  2. N
    Deciphering a T6 (V5) Model number - Conflicting Information ?
    Things never seem to be easy, when it comes to learning exactly what you’re getting ? I’m looking at buying my first T6 conversion, and I’m trying to make sense of exactly what the model is I’m contemplating; primarily to know (without a shadow of a doubt) that it has a EURO 6 engine so I’m...
  3. Pauly
    T6 VW T6 Electrical Coupling Points 2016
    Diagrams/Listing For All Coupling Point Locations Includes location/designation/connector colourings/pin count VIP Membership is required to download this document Below is a sample image of part of the document
  4. Pauly
    T6 VW T6 Control Modules (Rear) 2018
    Diagrams/Listings For Control Modules Around Middle Area Of Vehicle Includes control module names/locations/functions/references/pinout numbering VIP Membership is required to download this document Below is a sample image of part of the document
  5. Pauly
    T6 VW T6 Control Modules (Middle) 2018
  6. Pauly
    T6 VW T6 Control Modules (Front) 2016
    Diagrams/Listings For Control Modules Around Front Of Vehicle Includes control module names/locations/functions/references/pinout numbering VIP Membership is required to download this document Below is a sample image of part of the document
  7. Pauly
    T6 Climatic Air Conditioning Wiring Diagrams 2018
    Climatic HVAC circuit diagram Please check the history/updates tab, first release is for early T6s manufactured from June 2015, second release is for vehicles manufactured from June 2016 onwards VIP Membership is required to download this document
  8. Pauly
    T6 Heated Seats Wiring Diagram 2017
    T6 Heated Seats Circuit Circuit Diagrams Please check the history/updates tab, first release is for early T6s from 2015, second release is for vehicles from June 2016 onwards VIP Membership is required to download this document
  9. Pauly
    T6 VW T6 Earth Points 2016
    Diagrams/Listing For All Earth Point Locations Includes earth point reference number and relative torque values Also check out the earthing concept literature which may be handy in conjunction with this document https://www.t6forum.com/downloads/earthing-concept-wiring-diagram.240/ VIP...
  10. Pauly
    T6 Basic Equipment Wiring Diagram 2018
    Wiring diagrams covering basic vehicle equipment including various sensors, switches and controls VIP Membership is required to download this document
  11. Pauly
    T6 Aux Battery (non camper) Wiring Diagram 2018
    Second battery wiring diagram for factory fit underseat batteries This covers panel vans and kombi vans, not applicable to any California nodels VIP Membership is required to download this document
  12. Pauly
    T6 VW T6 Relay Locations 2018
    Relay Chart/Listing For All Relay Locations - In Engine Compartment, Adjacent Fuseholder SA In Dashboard, Integral To Fuseholder SC Under Left/Right Seat, Integral To Fuseholder SH VIP Membership is required to download this document Below is a sample image of part of the document
  13. Pauly
    T6 VW T6 Fusebox - Fusebox/Fuse Chart SB - Engine Fusebox 2016-09-27
    Fuse Chart/Listing For Fuse Holder SB - Left Side Engine Compartment This fusebox contains the majority of engine circuits VIP Membership is required to download this document Below is a sample image of part of the document
  14. Pauly
    T6 VW T6 Fusebox - Fusebox/Fuse Chart SF - Lower Dash Fusebox Listings 2016-09-27
    Fuse Chart/Listing For Fuse Holder SF - Lower Dashboard Compartment Located in central recess underneath gear lever VIP Membership is required to download this document Below is a sample image of part of the document
  15. Pauly
    T6 VW T6 Fusebox - Fusebox/Fuse Chart SD - Lower Dash Fusebox Listings 2016-09-27
    Fuse Chart/Listing For Fuse Holder SD - Lower Dashboard Compartment Located in central recess underneath gear lever. VIP Membership is required to download this document Below is a sample image of part of the document
  16. Pauly
    T6 VW T6 Fusebox - Fusebox/Fuse Chart SC - Lower Dash Fusebox Listings 2016-09-27
    Fuse Chart/Listing For Fuse Holder SC - Lower Dashboard Compartment Located in central recess underneath gear lever, this fusebox contains the majority of supplies to internal vehicle equipment VIP Membership is required to download this document Below is a sample image of part of the document
  17. Pauly
    T6 VW T6 Fusebox - Fusebox/Fuse Chart SA - Primary Battery Fusebox 2016-09-27
    Fuse Chart/Listing For Fuse Holder SA - Engine Compartment Located in 'E-Box' underneath battery, this fusebox contains the primary heavy duty feeds from the battery to main vehicle equipment VIP Membership is required to download this document Below is a sample image of part of the document
  18. Pauly
    T6 VW T6 Fuse Boxes - Overview Of Fuse Holder Vehicle Locations 2016-09-27
    Fuse Holder/Fuse Box locations for all VW T6 Van/Kombi/Caravelle vehicles VIP Membership is required to download this document Below is a sample image of part of the document
