travelin-lite
  1. T6 LYE
    Travelinlite Facelift kit issue ?
    Hi all, has anyone bought the Facelift 6 to 6.1 kit and do you have to do any wiring mod as I've bought their Headlights but have a couple of issues which im trying to sort. No sidelights on front only with key removed… and rear indicators sometimes miss a flash with dash arrow flashing quicker...
  2. N
    Gloss black grille: badge doesn’t fit
    Hi, I’m hoping for some advice and direction please. I’ve changed my front bumper to gloss black trims and I cannot for the life of me get the gloss black badge to clip in. I’ve tried it with the bumper on and off as well as having the grill detached. Still with no luck. I have broken the...
  3. Garyde
    Sealing up leaky DRL's?
    Hopefully someone can help with this... I've got a set of the Travelinlite lower grill DRL's fitted to my van, but unfortunately they filled with water after less than a year of being fitted. To Travenlite's credit they sent me out a replacement pair quickly, but I've not yet got round to...
  4. R
    T6.1 style taillight comparison: Travelinlite Vs THQ
    These lights seem so similar. Is there much difference in looks, quality or function? I really want 2x dogs and 2x reverse lights (and no errors!) https://travelinlite-transporters.co.uk/collections/t6-rear-lighting/products/pre-order-t6-tailgate-led-rear-lights-with-dynamic-indicator...
  5. F2JON
    Sold T6- t6.1 fog lights
    Free to a good home, anyone that wishes to collect I’m not posting them, they’re travelinlite fogs not genuine, I’ve replaced them with genuine as they kept misting up but I think it was down to the bulbs I had in . Hence I’m giving them away before I bin them . There’s three in total two...
  6. J99kom87
    Aftermarket Fog light kit issue
    Morning all after a bit of advice regarding the aftermarket travel-in-lite fog light kit with auto headlight switch. So they’re installed and they work great my only issue is when the auto headlights come on it also turns on the front fogs. When I turn headlights on manually the fogs stay off...
  7. C
    Travelin-lite TL-RS rear bumper
    Has anyone fitted the new TL-RS rear bumper yet? https://travelinlite-transporters.co.uk/products/t5-t5-1-t6-tl-rs-rear-bumper-03-12
  8. V
    TravelinLite Power Fold Mirror retrofit 2016 Shuttle
    Right, I've just recently bought the aforementioned kit to upgrade my current T6 heated mirrors to the power fold versions: T6 15-20 Electric Power Folding Mirrors (upgrade kit) I consider myself pretty handy but the instructions provided are pretty poor in my opinion. PDF Viewer...
  9. I
    Travelin-Lite - bumpers and grilles
    Post images please :)
  10. C
    T5.1 to t6.1 headlight diode
    Hi, First post here, did subscribe to the vip section in the hope of finding this information out without posting but could not find what I was looking for. I am doing a t5.1 to t6.1 facelift, I have sourced the parts myself, so did not but the ‘complete’ travelinlite kit. Have just been...
  11. stupot
    Before I blow myself up… LED to halogen wiring
    Hi all I want to remove the LED main beam bulbs and switch to halogen, in my Travelin-lite headlights. There’s a red and black wire (see pics) going to the LED and it’s little canbus block thingy (you can tell I know my stuff). Is it as simple as unplugging those 2 spade connectors and attaching...
  12. Alster
    Travelin lite door seals
    Just fitted the travelin lite door seals and really pleased- doors shut with a nice clunk . But just a bit worried that they will fill up with water, should I cut a drain hole in the bottom or am over thinking this. What have others found?
  13. F2JON
    Sold T6.1 splitter
    brand new never fit brand new never fitted change of plan, can take to camperjam if I receive payment before. £100
  14. P
    Found Sportline fog surround.
    Hi looking for the passager side fog surround for a genuine sportline front splitter. If you have a spair would be amazing Thanks
  15. SAF1981
    Has anyone bought Travelin Lite T6 Tailgate LED rear lights with dynamic indicator (T6.1 style)
    Has anyone bought the T6 Tailgate LED rear lights with dynamic indicator (T6.1 style) sold by Travelin Lite?
  16. Barley53
    Sold Travelin-lite v2 headlights
    A pair of used aftermarket headlight units from travelin-lite. These are their version 2's, non-sequential bulb indicators that run with either halogens, xenon or led dipped. I've had them on the van about 2 years and they have literally been all over the country and all things considered are...
  17. Barley53
    Sold T6 swb wheel arch trims
    Hi, I've got a complete used set of the above purchased from Travelin-lite, they were on the van for about a week before I took them off - friendly warning, they are not entirely compatible with the Kiravans door storage. Pictures attached; they are the swamper style which add a beefier stance...
  18. T
    Travelin-lite reverse camera
    Hi all. I am literally at my wits end. I have installed a reverse camera but I cannot get it to work!!! It is the wired sort with a delay module. The live pig tails on the camera cable are wired to the fuse 19 piggy back and to the green and black wire which I thought was the reverse light?? I...
  19. M
    Traveling-lite power mirror control box issue?
    Hi, I’ve installed power fold mirrors using the Traveling-lite module. Does anyone know why it needs soo many extra relays to function when compared to the simple solution you can get for £20 on eBay? BTW looks like one of those cheaper solutions is incorporated into the travelin lite option.
  20. T
    Headlight level switch not working with H7 [Resolved]
    Hi, I have travelin lite led headlights on my t6 and noticed this morning that the headlight level switch is no longer working when I tired to adjust them. I noticed that the dash light adjuster is still working and if this is part of the same switch unit would rule out a blown fuse ? If anyone...
