turbo problem
  1. nonlineartom
    T6.1 BiTurbo dead at 143K :(
    I purchased a T6.1 T32 199PS just last week, 20 plate, with 142k miles on the clock, I knew it was high risk with the mileage but there was a full service history for oil change every 10k on the dot, new belt and pump, all the stuff I thought I had to look out for. It was just about in budget...
  2. J
    Possible Turbo Replacement?
    I'm new to this forum but would welcome any advice. Have had an issue over the last 6 months with high oil usage on my 2015 Caravelle, 125k miles done - oil seems to be burning off, white smoke seen from exhaust. No leak was found by garage. Then a couple of weeks back the flashing coil light...
  3. L
    Wet Turbo
    Hello today I changed the glow plugs in my CXEB 204 ps and saw a wet turbo. When driving fast I'm leaking a lot of oil. Is it the turbo or the inside of the engine that needs work?
  4. L
    2019 204PS BiTDI engine failure
    Hello, new to group despite owning several transporters. Could really do with some help and advice from others who have experienced engine failure due to low cylinder compression. Van started running lumpy in low gears, then came the exhaust smoke, immediately stopped driving, P100400 fault on...
  5. M
    Turbo replacement gone bad :(
    Some of you may remember my po299 underboost woes, well, we finally got to the point of Proving the underboost and diagnosed the turbo Not quite making enough boost…., I’ve had to wait to save up some cash to continue with the turbo repair, but I’m on with it now. So turbo off for a recon or...
  6. L
    2017 Velle Bi-turbo gone, main dealer or go indy?
    had my 50k miles caravelle since 2017 and all work has been done with the cambs main dealer. bi Turbo just went at start of road trip so its completely off the road now. Any opinions on main dealer Vs breaking out and going indy with someone good? -looking for recommends on that. the whole...
  7. A
    About to become the owner of a Caravelle T6 4Motion upgrading from a trusty Seat Alhambra as the family is growing. Only just registered here but the forum has already been a treasure trove of info. I hope to be able to give back once my knowledge picks up.
  8. D
    BiTDi failure [Resolved]
    Hi all, my 2018 DSG bi turbos low boost turbo has failed at just 31,000 miles! The van has been well serviced with regular oil changes. The engine management light came on and my local garage said it was probably just a sensor that was faulty so I carried on driving the van for a week while I...
  9. W
    Intermittant Limp mode stuck turbo actuator implausible signal
    Hi Long time lurker here and now a new member because I had to reregister an account. Hoping that someone can shed some light before delving further or taking the van to the main dealer or specialist. Was driving the van last week and when I put my foot down to overtake it kind of stumbled...
  10. Exit_the_Ratrace
    2017 204 Bi-Turbo Engine Swap by VW Main Dealer
    Hi, long time reader first time poster here. I am finally getting my engine swapped under warranty from VW. Engine is ordered (paid for by VW) and hopefully installed within the next week or two. Question is, what else is worth swapping / upgrading whilst the block is out and easy to access...
  11. P
    What is this leaking component? Intercooler?
    Hi everyone, I was planning on going to look at a t6 on Saturday, it is 4 hours from where I live so asked for a walk around video, when looking at the engine it looks like something is bubbling? Is this the intercooler? Is it a big problem? I don't want to do an 8 hour round trip for a lemon...
  12. F
    No power after 120km/h for 10/15 seconds.
    Hello everyone, im a t6 owner and new on this forum! 2.0 TDI 2016 DSG, Im loosing power after 120km/h for 10/15 seconds, after 10/15 seconds works normal but dont want to change gear 7, sometimes works perfect and sometimes no. What I've checked: Both Turbo Boost Sensor, one near EGR pipe. Made...
  13. Ashok2429
    2018 204ps Turbo gone @96K -To be expected, early or just unlucky?
    Hi all, So on the way down to Cornwall last week, got as far as Exeter, van went in limp home mode with an all mighty screech coming from under the bonnet. Managed to get her off quickly at the next service station and rang the RAC. This isn't thread about how poor they were (they left the Mrs...
  14. piper1
    Advice needed please
    Hi, I hope some can help me identify a problem with my van that occurred yesterday. We set off for a 4-day break yesterday with the caravan in Wales and whilst traveling along the A55 and we had to make an emergency stop, the van appeared to lose power whilst going uphill at the same time...
  15. RunDSG
    2017 204PS BiTDi - Seized turbo!
    I guess it's my turn? Driving up to Caravan and Camping Show, coil light starts flashing, ad blue suddenly low (topped up fully one week prior), no power. Engine temp fine, oil fine, engine sounds fine. Turned around and went home. Brought to a VAG specialist garage, they say: - split vacuum...
  16. S
    Sportline Turbo problem [Resolved]
    Hi Everyone, I have a problem with my Sports line T6 on a 68 plate. While travelling on the motorway the van went into limp mode (40-50mph) once I got home and restarted it wouldn’t go any faster That walking pace. I took it to a garage I normally use, they told me it was the Dpf filter and...
  17. J
    No communication, boost pressure warning
    Hi all, First post, sorry to start with a disaster. And sorry in advance if I get terminology wrong - not mechanically competent at all. Love my SWB Caravelle 2L DSG. 2016 reg, had some minor issues with DPF needing regen and a replacement EGR before. But nothing as big as now - might not be a...
  18. J
    Hybrid 204ps anyone ??
    Hi all So my small turbo has given up and snapped the shaft on my t6 204 sportline So question is do I hybrid them? Tdi turbos have said they can do them and will send a courier tomorrow Good for 300bhp I believe Anyone done this? Also does anyone know the maximum flow rate = bhp the...
  19. J
    204 t6 small turbo help
    Hi all I have a t6 204 35k with a small turbo not working I have checked all the actuators and they hold pressure But I can't see the one at the very top, I can't see the arm move as there is no visibility to see it. The other two I can see and they hold pressure and move perfectly...
  20. M
    2017 - 150BHP Euro 6 - Seized Turbo - Not getting Oil
    Hi, Hopefully someone can help. I have a 2017 Euro 6 150BHP T6 Transporter. Now, i haven't had the van long and i like to stay onto off servicing and making sure they are in tip top condition. There was an oil pressure warning light on the van (the red oil can light, i believe this is the high...
