twin monotube projekt
  1. 5n0wb0mb3r
    Projekt Monotube
    Hi guys, My new van comes with Projekt Monotube coilovers on it. Does anyone have any experience with these? I'm told they're decent, but can't really find much info on them. Cheers Jim
  2. Chilli Jam Vans
    New TMP 16XL comfort coilovers - new to the UK market
    Something a bit different that's recently been introduced the market is this TMP 16XL comfort coilovers. Amazing bit of kit, TUV approved German quality like all the Twin Monotube Projekt lowering and lifting products, and we are offering free fitting for anyone interested in these and willing...
  3. BlayneKinley
    Wanted Twin Monotube Projekt AT alloys
    Kind of feel like I’m peeing in the wind with this post…. But if you don’t ask you’ll never know! Has anyone got a set of 17” or 18” Twin Monotube Projekt alloys they wish to part ways with? Thanks, Blayne
  4. W
    Sold New (unfitted) T32 Twin Adjust Projekt Sensitiv Coilovers (40-70mm) - £1150
    Hi all, Ongoing change of plans for our van and various parts being sold. Have a set of these excellent coilovers for sale which were purchased, received, I opened the box to check them, and then they have never been fitted. Going in a different direction with the van now so wondering if anyone...
  5. T
    Clonk / bang over bumps - coilovers
    Hi guys, So since fitting the coilovers (twin adjust project low), I have discovered a bit of a ‘bang’ at the back when going over a harsh bump quickly. Although not a major issue (most roads, bumps etc are fine) I still want to solve it. I ‘think’ its the collars if I am honest. I removed the...
  6. N G Neer
    Twin adjust Projekt MAX LOW coilovers T26-T30 50-90mm (Eibach / Koni Kit) fitted.
    I ordered these from @Chilli Jam Vans They were really helpful and the kit was delivered within a couple of days. I've already posted in my build thread but here's a couple of pics. Wound all the way down on the front- 90mm drop and about 3/4 down on the back. Nice comfortable ride and just...
  7. K
    Found Wheels and Coilovers
    Looking for any of the following wheels: - ABT, - BBS, - Navis GP7, Looking for Coilovers: - Twin Monotube Projekt, - Twin Adjust Projekt LOW, - H&R Deep
  8. Eli
    Who’s got what suspension
    You may have something that isn’t listed so let me know and I will add it to the list
  9. O
    Twin adjust projekt install question.
    Before I start installing these I’ve a question if someone could help. On the fronts the bottom of the threaded sleeve to adjust the height, does this just sit metal on metal against the lip on the strut. Didn’t know if there should be some sort of protection between the two?
  10. D
    B14 Komfort or Projekt Sensitiv
    Hi everyone. New to the forum. I am currently using Eibach 50mm springs and B8 Dampers. The ride is awful, especially on the wonderful UK roads. I want to get either the new B14 Komfort or the slightly cheaper Projekt Sensitiv kit. Has anyone got these relatively new kits or had a chance to...
  11. Keaney
    20" Tyre Advice - sizing / brand / pressure
    I've now picked the alloys and dimensions but what tyre brand are people using on 20’s Been quoted on accelera which was really cheap and may go down this route initially but normally stick to main brands, yoko, Pirelli and Michelin etc
  12. The Van Cave
    The Pursuit of Suspension Happiness
    Yep, it's another suspension thread and it's a fairly long winded one, but...... It's time to move on from my B14s. It's important that I choose well this time, mainly because it's fairly expensive, but also because whatever I end up choosing will form part of the catalogue of upgrades I'll be...
  13. TomLawrence
    T6.1 20” Wheels Rubbing Under Max Compression
    Afternoon all, just stuck a new set of 20” rims (staggered 8.5 front, 10 rear) on my T6.1, it’s now rubbing under maximum suspension compression. It’s dropped 70mm on Projekt Sensitiv coilovers. Anyone else had this problem? Cheers Tom
  14. D
    Suspension recommendation for campervan.
    Hi Guys. I must say at the outset that I have absolutely no technical knowledge whatsoever so I would really appreciate some advice please. I have factory order for a T6 Kombi Highline SWB T32 15o DSG, delivery September. It will be going for a camper conversion straight away! I would like to...
  15. Coradia63
    Twin-Adjust-Projekt-Sensitiv (Eibach + Koni) comfort coilovers?
    Interesting... NEW comfort coilovers for VW Transporter | Chilli Jam Vans
