I have just removed the underslung water tank from my LWB T6.1 having never used it. It's been on the van for c. 8k miles, but has never had a drop of water in it, so the insides should be pristine.
I think they retail for between £150 - £200 new, so make me a sensible offer... I just need rid...
Random question but I noticed this just under my new T6 (T32) van, which has been on the drive for a few days while I’ve been going in and out of it and also taking the dashboard apart to fit a new stereo.
With all that going on, it makes me think it from the van - does anyone recognise it ?
I got a Cali Beach T6.1 and bought spare wheel fresh water tank. I'd like to add water sensor there and ideally hook it up to the control unit - like Ocean models have it.
Anyone did such modifications? Heard anything?
Have an underslung water tank, 68L however, I can only seem to get it to fill to 36L. (I know this as have emptied it into a tank I know the exact size of multiple times)
When I fill, i can hear the water going in tank. I've left it up to an hour filling and can always still hear the sound of...
For those that have installed the underslung CAK sill tank, what route did you take for the 40mm filler hose and the water pump?
I would like to install my water filler cap on the panel between the B pillar and the C pillar such as in the below example.
after some assistance if anyone can help I have a LWB t6 which I have just started to convert I have purchased and just started to install this Fresh water tank Tank seems to fit well and is really easy to install. I am a little stuck with the hose routing Ideally want to have the...
Hi there fellow VW campers - our T6 has an underslung on board water tank capacity approx 60 litres we are having problems with filling it - the filler is situated inside the cab near the sliding door by the base of the rear seat , when we try to fill it with a hose from the mains -however...
Hi all I’m a new member and after some help/advice. I recently bought at SWB T6 T32 Dsg 4motion converted Kombi with 2 sliding doors, I am hoping to put gas underneath and hopefully water fresh and waste water if there’s room, I don’t really want to loose the spare wheel. Has anyone had this...
Hi all, it’s my first post but definately won’t be the last! I have a 2020 Highline full camper with underslung water tank. The filler is on side of body at side of EHU port. It is I think, a whale type filler as I have a 7.5m lay flat hose and whale connector to fill from a hose. I have not...
Hi, we have a T6 shuttle, with a Hilo roof aswell as an Ovano draw / bed system installed, the vechile is mainly used for short weekend escapes. We have been using a large 15lt jerry can for water, this is a pain !. We are looking to install an under slung water tank & pump with exterior fill...
Good morning all,
I have a new/unused twin skirt water tank kit. Had a slight change of plan on our layout so went for a different water tank. It's never been installed.
Looking for £180 collected from the Manchester area or I work in chesterfield so could also be collected from there too...
We recently completed a camper van conversion on a T6.
As part of this we developed a water tank that fits in an unused space behind the N/S/R wheel to use as a waste tank and had a drain pipe fitted.
Since then I have fitted one to my own van (T5) to use with a cordless pressure washer for...
Hi - completely new to all this having picked up our T6 a couple of weeks ago so will have lots of questions and hopefully this is posted in the right chat. Been looking under my van (Cambridge Camper Conversion) and found this connection shown on the pick. Looks like it comes off the water...
Thinking about fitting one of these
https://www.onlinetankstore.co.uk/product/vw-transporter-underslung-water-tank-69-litres/
They recommend TEK screws for the brackets. Will this be strong enough?
Has anyone fitted one with an under-bumper outlet and pressure-fill (with over pressure...
A change of build plans means this is no longer needed. I have already wrapped the tank in bubble insulation and foil tape to help insulate from both the heat and cold.
As new as not been fitted or used, comes with the fixing brackets and outlets.
Has the flush mounting access / drain cover on...
Hi, just planning conversation (first post here), looking to fit small LPG, water tank and propex heater all underslung in T6 LWB. Heater to go in usual place. Question I have is are the any examples out there of doing this? Trying to find the correct tanks etc. Everyone seems to have done LPG...
I have a cak tank 203f to fit under the vehicle behind the spare wheel for fresh water. It has a 40mm inlet connection point. The tank has 3 small white discs on the top which I presume are pressure relief valves so it can vent if over full. I wanted to fit just a conventional bayonet...
Hi can anyone assist with suppliers of underslung fresh and waste water tanks.
I have seen them advertised for LWB but not for MWB
I am also looking to add underslung gas so size and locations are critical especially with ad blue
Anyone here done this already ?
cheers phil
