vehicle battery
  1. P
    Found Battery jacket
    Hi, upgraded my battery from 70ah to and 80ah. Does anyone who has upgrade from an 80-95 have their old sleeve/insulation thing they no longer need and want to sell cheap. It's on back order from VW currently. 1J0915418C Thanks
  2. T
    Slow crank
    Morning all, I have noticed now that it's getting colder the van has a really slow crank when it starts. It does start and it does it as soon as it turns over but it is slow. Looking at my bm6 readings the voltage drops from about 12.3 to 11.9 which I thought wasn't that bad but I have no idea...
  3. J
    Unknown battery connection
    Can anyone let me know what the two connections are in the picture. Accidentally came away whilst disconnecting the battery 2015 T6 SWB
  4. Molldog
    Vehicle battery charging
    Possibly a daft question but I wouldn’t be asking if I knew. My T6.1 spends a fair amount of time sat on my driveway. I’m looking at charging the vehicle battery with my smart charger. I have the option of smart battery charging or regular battery charging. Which mode do I select?
  5. T
    Urgent help charging battery
    Trying to charge my father's battery with a ctek mxs 5, done my own multiple times, but when I try to do his, I can hear a noise in the engine and his dashboard lights are flicking on and off, but the battery does not seem to be charging, very strange, any help appreciated T2k2
  6. hudsons_autohaus
    All Lights flicker on Cold and Warm Start
    Hi all, My lights (interior and exterior, LED and non LED) have flickered on the van every time I turn it on whether its warm of cold and on auto stop start for as long as I can remember but for some reason now its starting to get on my nerves haha. So I was wondering if anyone new what my...
  7. Maarten1
    EHU under bonnet - flat battery
    My van is new to me and I had the first off grid trip away last weekend with no issues. When I got home I plugged the EHU in to charge the leisure battery. The EHU is located under the bonnet so I plugged it in, lowered the bonnet but didn’t close it all the way for fear of damaging the cable...
  8. M
    HVAC / Recirc clicking after battery died.
    Hi folks, Battery died when I was away on my 2016 VW startline. Had bizarre symptoms including doors locked shut and a bunch of blown fuses on the leisure battery side but fixed those with fresh fuses and resetting the codes after installing the new battery. Apart from the clicking. It...
  9. P
    New starter battery coding help
    Hi all. I require a new starter battery and I’ve read the thead on upgrading which I’m thinking of doing. If I do go down that route is the someone that can code it in local to me Dn14 area. 5 mins from jct 34 off the M62 for beer money. Or can I do it myself? Alternatively if I go with a...
  10. A
    Starter battery drain
    Hi, I have t6.1 with a ctek 250se and a Duritc battery charger. Just ordered a BM2 as the starter battery is being drained. The van is standing for weeks at a time and I’m leaving on the EHU at weekends but the charger is only charging the leisure battery. Is there a way to stop the starter...
  11. H
    How to charge t6.1 battery correctly
    Hi, Can someone please explain how I correctly charge my t6.1 110bhp engine battery? Looked online and different opinions as to where to put the earth? Sorry to ask a silly question to all you professionals!
  12. S
    Battery drain or dodgy battery?
    Hello hope you are all well. I have a 2021 T6.1. Every now and again in the morning it would struggle turning over, but would always start. When this happened the dash always showed "VCC error", along with some other errors (I cant recall right now, but I think it said the senser that the...
  13. J
    How long before the battery dies?
    Hi everyone I am away for a few weeks so my van which is my everyday will be sat on the drive. How long before the battery dies, should I get my neighbour to turn it over from time to time? Thanks in advance.
  14. AYRGUNN
    Battery dying [Resolved]
    Hi all, looking for some advice. I work away for two weeks at a time and when I get home my battery is dead. There are no lights left on or anything like that so wondering what could be draining it?. I have a usb port and reading light installed with 4 down light in the back. Thats all thats...
  15. CrazyDunk
    Solar Install & Mystery Vehicle Battery Drain
    Firstly, my set up: 90ah agm leisure battery CTEK dc to dc charger Victron Ac charger T6 2019 Highline camper conversion with low mileage of 15k on the clock Job last week carried out by professional installer: Upgraded agm leisure battery, now 130ah Installed solar and connected to CTEK Tidied...
  16. Adam H
    Bigger starter battery
    Hi all, Got a 2019 T6, original battery and its been playing up for a while. Last few weeks its taking longer to crank, not much but enough to be slightly embarrasing if it churns away for 5-10 seconds before biting. It's got a fair bit running off of it now like trackers and alarms...
  17. Ian28
    Halfords EFB096 Starter battery
    Hi, my starter battery appears goosed after a long period of inactivity. Needed jumping before the CTEK would recognise it and after nearly 24 hours charging/reconditioning it started but after driving a short while the battery light came on and it now won’t restart. It’s a Varta in it but can I...
  18. R
    Vehicle Battery removal
    Hi, I need to remove my starter battery and want to know what problems might occur when replacing it. I've seen that I may need to reset the one touch window procedure lowering down then up again other than that is there anything else I may need to reset? the battery will probably be...
  19. Paul Sussex
    New battery - control panel lights
    Hi, Had a new starter battery fitted by local garage. Been on a few longish runs 70 miles round trip and 30 miles. The control panel is still showing not full, do I need to do more miles or could it be something else? Going back to the garage but they say not camper experts so may need to...
  20. P
    Stop/start error after battery swop
    Hi. Just fitted a new 95ah starter battery after which the MFD is showing a Stop/Start error when switched on. Also Carista is showing Battery Monitor Module fault. Battery has been registered with the Carista. Any thoughts and is the van ok to drive? Thanks for your thoughts.
