voltage regulator
  1. H
    Flickering LED ceiling light when heater start/stop.
    Hi, I've got a T6 fitting with a 110Ah AGM battery. This is then connected to a fusebox via 2 x 70amp cables (plus and minus). To the fusebox I have amongst other things 6 x LED's and a Webasto Air Top 2000 heater connected. The LED are fine, they work as curtesy light and can be switched on...
