warning light
  1. SAF1981
    T6 low pressure sensor location?
    Can anyone point me in the right direction to locate the low pressure sensor on a 2016 T6? I'm having a yellow low oil pressure warning light flashing and going to replace the sensor. Should be the reason as I'd just had a oil service 3 wks ago.
  2. 22jeffers
    Random Dash Lights
    Hi all A couple of days ago I noticed my rear diff and seat belt warning light come on at the same time. I’m not quite sure about the rear diff light but the seat belt light was dim. I was wearing my seat belt and when I unplugged it the seat belt light illuminated double the brightness. But...
  3. M
    LEARN TO FIX YOUR OWN VAN.....a cautionary tale for the unwilling and reluctant.
    Something came up recently that I was stumped on - and id forgotten what a massive rip off paying someone else to fix your van can be. Wrote a bit on self knowledge that you might find amusing. CLICK THIS LINK TO HAVE A READ!
  4. T
    Clearing the Air bag warning light
    Folks, I have tripped the airbag light on the dash during the course of a small mod I was doing. I removed the front passenger seat to explore the leisure battery and gubbins under there. With the seat removed I fitted a CTEK indicator connector to the battery for future hook-up's When I removed...
  5. SkyMonster
    Seat Belt Light On.
    I removed my drivers seat a couple of days ago and refitted it. I forgot to re connect the connector under the seat which i believe can cause an Airbag light fault but my issue is i have a Seat Belt light even though the connector is back on now. I ran a diagnostic via a dongle but its not...
