I have a diesel heater in my van which we haven’t used for about 4 weeks, turned it on last night and water started leaking from the front of the heater into the van, any ideas?
ELGENA KB3 12V/230V WATER HEATER (12V-200W AND 230V/660W)
Was removed from new conversion for the KB6 heater. As new and tested. Ideal for hot shower at rear of Transporter
£195 plus P&P
I’ve been looking at getting hot water for camping. My van is a lwb with a playaway bed (so no furniture). I don’t really want to drag a gas bottle around for the likes of kampa geyser unit.
Can anyone steer me in the direction of whether my existing Factory block heater (webasto thermotop...
Looking at fitting something for making hot drinks in our service vans and found www.transvend.com They say their 2 litre insulated boiler heats up from 10 degrees to approx 95 degrees in just under 30 mins on a 30a 12v supply. Can then be set to either keep hot (heater kicks in again at 5...
I am converting my shuttle to a camper.
I will have no need for the rear heater or roof vents so I was going to whip the motor and rear rad out etc.
I do however have a plate heat exchanger which I brought for a Veg conversion years ago which never happened.
My question here is, could I use this...
Was wondering if anyone can recommend a diesel air and water heater. Need a diesel air heater but want to have the hot water heater as part of the same unit. Any make will do as long as it's reliable and can heat a T6 SWB as well as provide hot water for a shower.
Hi Everyone,
New build here and need some help from and advice. The goal is to have water pump and water heater enough to have a hot shower out the back. The heating system I already have installed is Propex HS2000 undermounted with a 15L LPG tank placed in the space where the diff goes on a 4...
I just got my California Beach T6 and am looking to install a water heater. The idea was to take it of the Webasto Thermotop Evo coolant heater that comes with the new T6's. However the dealer in Spain told me that those aren't installed in the Spanish T6. However looking on the inside of my...
