water tank
  1. willgr
    For Sale Underslung Watertank 69L (fits T5 onwards)
    I have just removed the underslung water tank from my LWB T6.1 having never used it. It's been on the van for c. 8k miles, but has never had a drop of water in it, so the insides should be pristine. I think they retail for between £150 - £200 new, so make me a sensible offer... I just need rid...
  2. B
    Interlan water tanks: how do you secure them ???
    How have you all secured your water tanks to stop them falling over? Is there some kind of basket that can be attached ? Ideally like something that looks good rather than bungee cords etc. thanks
  3. M
    Fresh water level sensor on CU display
    I got a Cali Beach T6.1 and bought spare wheel fresh water tank. I'd like to add water sensor there and ideally hook it up to the control unit - like Ocean models have it. Anyone did such modifications? Heard anything?
  4. J
    Slidepod slim water tank.
    We've just fitted a slidepod into our 2018, 7 seater T6 and I want to try and retain use of all the seats for the daily drive. The problem is if we place the water tank for the slidepod behind the rear bench we lose quite a bit of space. Has anyone ever sourced and installed a slim/low tank...
  5. S
    Waste pipe from a sink - in or out?
    Hi all, I've been to see a conversion company and they suggest it's best to run the waste pipe from the sink through the floor and put a container under the van to catch it. Is that normal? I'm concerned about the extra road noise from the hole and letting cold air in. Where does your waste...
  6. T
    Water Tank Lock seized
    Hey all, so I've managed to allow my water tank lock to seize through lack of use. I've managed to free it slightly so the key goes in about 5mm or so but it just won't go any further and therefore can't open the tank to flush and fill. There's three screws holding the surround plate in place, is...
  7. S
    Fresh water system deep-clean!
    Hi All, Not sure the best place for this? My van has been sitting for a few months with water still in its cold water tank (for the tap over the sink - not running). Whats the best way to clean it? beer line cleaner or something?
  8. T
    Underslung water tank help.
    Hi all, after some assistance if anyone can help I have a LWB t6 which I have just started to convert I have purchased and just started to install this Fresh water tank Tank seems to fit well and is really easy to install. I am a little stuck with the hose routing Ideally want to have the...
  9. S
    Camperking Water Pump Access
    Hi All I think my sink water pump has failed in my T6 Camperking conversion. Does anyone know how to easy access the pump before I start taking everything to bits. Fuses and switches checked and everything seems fine so thinking the pump is goosed. Many Thanks
  10. Chris Sherwood
    Sold Campervan Fresh Water Tank
    Now sold I have a fresh water tank which I removed from the bottom of my camper wardrobe when I put a water tank under the van. It is approximately 45cm X 16cm across and 26cm high. It has a filler, overflow, vent, outlet, access hole fitted and the old submersible pump is still in it. I am...
  11. C
    Underslung tank installation cost?
    For Sale - 2018 T32 Campervan | 150PS | £35k upgrades Any idea how much it would cost to have an under slung water container installed?
  12. N
    Fresh-water filling problem
    Hi there fellow VW campers - our T6 has an underslung on board water tank capacity approx 60 litres we are having problems with filling it - the filler is situated inside the cab near the sliding door by the base of the rear seat , when we try to fill it with a hose from the mains -however...
  13. kjohnr2001
    Sink water pump airlock woes
    Morning all, drained my water tank via the bottom drain a couple of weeks ago and stupidly opened the tap to make sure it was fully drained. I appear to have got an airlock in the system - having read the threads on here, the advice seems to be to switch on the pump, open the tap, suck through...
  14. M
    Water Pump problems
    We have an Exploria conversion with a Sureflow Trail King 10 water pump for the sink. This seems to have cracked over the winter, despite my best efforts to drain the system by emptying the underslung tank, and then running the pump until the system was (supposedly ) empty. The tap was left...
  15. L
    Sold 24L wheel arch water tank - new with accessories
    New in box 24 litre wheel arch water tank for transporters. Black in colour. As per item in link and complete with fitting kit and plumbing kit. https://camperinteriors.co.uk/products/campervan-24-litre-wheel-arch-water-tank?variant=15425379827806 £70 (£118 new) Collection from SW London
  16. Samfisher
    Auxiliary water pump
    Hi My battery goes dead after a couple of days even if I use it daily. Now the electric water pump stays on even after it is left for a few hours. I have unplugged the pump and there is still something else making a noise, it sounds like a smaller pump. If I disconnect the battery then re...
  17. V
    Sink water pump
    I've had my T6 for 2.5 years and the water pump for the sink hasn't worked for 95% of that time so desperately hoping for some help. Setup is as shown - it has worked very occasionally (although more like a dribble of water and always temperamental). More recently it stopped working completely...
  18. T
    Sold Twin system Water tank
    Good morning all, I have a new/unused twin skirt water tank kit. Had a slight change of plan on our layout so went for a different water tank. It's never been installed. Looking for £180 collected from the Manchester area or I work in chesterfield so could also be collected from there too...
  19. O
    T5/T6 NSR underslung water tank
    We recently completed a camper van conversion on a T6. As part of this we developed a water tank that fits in an unused space behind the N/S/R wheel to use as a waste tank and had a drain pipe fitted. Since then I have fitted one to my own van (T5) to use with a cordless pressure washer for...
  20. GingerPig
    Sold CBE Waste Water Tank Level Kit
    Motorhome and campervan waste water tank level kit from CBE consisting of a tank test panel with coloured LED indicators, tank probe and wiring harness. This kit is ideal if you are retro-fitting a waste water tank or if you don't already have a level monitoring facility as part of your 12V...
