Our T6 has a Webasto airtop 2000 stc diesel heater fitted complete with the external temperature sensor and runs from the rotary dial. When we run it on around the 3rd marker on the dial it heats the van up to around 21C and then slows down the fan and then stops altogether. Without...
Hi all you knowledgeable people! So glad to have found this place
We have a webasto air top 2000 and can not by the life of us find the combination timer! It's in an older bus and we have looked everywhere for it but can't locate it. It currently doesn't blow hot air and the control element is...
First post so go easy on me!
Just bought myself a 67 reg Ex AA T6. Having a little rummage around before I start converting and I've found a wiring harness under the seat.
Most of the wiring is for the tow bar and im happy I know what it all does, the second part is basically and ignition live...
As per titile.
This was fitted by camper converter 18months ago & seems fine when the engine is not running, but start the engine (as I've used it to help defrost the van over the last few days) & it starts making a wierd noise and smokes like an old steam train.
Turn the engine off & it...
Will be listing it on the bay of E next week (March) as there is no interest here. ( I will not bother doing any more for our vans as the interest is so poor)
New 12v Webasto Air Top 2000 STC underslung diesel heater kit.
Proper sturdy Webasto mount - not one of the flimsy Ebay ones.
New, has...
Hey there, has anyone ever tripped there Webasto Heater whilst it was in? Stupidly I knocked my isolator when the heater was on and it’s giving me the error code H06, has anyone tripped there’s before and do they have any solution to this? Fuse is fine, didn’t smell any fumes or nothing.
Choice of heaters - see last pics. ( both new, have been fitted once and then tested by me after removal )
New 1.1m waterproof neoprene ducting + 0.5m interior ducting...
Likely a stupid question but ill go anyway.
I’ve got a Webasto heater with a control knob (don’t have a pic to hand) which doesn’t have a digital temp gauge.
If I put it on the lowest will it heat up slightly or just be in effect a fan?
Off to France on Friday and might buy a plug in fan...
basically started accumulating parts a few years back to retro fit this to a panel van using genuine parts.
genuine Webasto air top. with bracket
drivers vented step ( cold air intake)
B pillar post with outlet vents
b pillar ducting
pretty much everything you need to retro fit the heater with...
Hi Guys, just got a T6 camper 150 DSG……delighted with it so far.
It has a Webasto diesel heater fitted. I understand the heater air intake is through a circular vent in the driver’s side door step and the heater outlet is obvious behind the driver seat, but what is the purpose of the circular...
I have a 2000 D (diagnosis) that has had a cable with a female connector soldered into one wire of X1.
I see from the manual this is the control unit connection for the combustion and heating air fan, but does anyone have any ideas as to what kind of external thing you would link up to this...
Full kit new Webasto Air Top 2000ST Petrol Heater with Telestart - new old stock heater, new T90 Telestart - up to 600metres range.
All parts new except rheostat backplate.
Will have ducting/venting to your requirements and mounting plate if possible to supply what is needed.
Not the cheapest...
Used Webasto Air Top 3900 Evo 3.9Kw heater - petrol. Very low working hours approx 350 hrs only.
This is a heater that is made up from various parts by myself with a new burner and glow pin, used motor with less than 300 hours working, non-original case. All checked and tested.
OEM exhaust and...
When I got my T6 Kombi there were multiple combinations of parking heaters. Coolant-based, Air, both, with/without remote. I specified the most expensive option, everything:
Programmable parking heater (air) with radio remote control, auxiliary heater (coolant-based) and second battery
I did...
Please forgive me, I have read the two main threads on aux heaters (Link1, Link2). I have the same questions as most.
How to get my aux coolant heater to heat the engine \ cabin without the engine running.
My vehicle, Caravelle Exec build date July 2020, has factory fitted Aux heater...
My petrol Webasto gave up last week. I awoke in the night to a flashing error code (F 02 - Flame Failure), which usually resets OK but not this time.
When this has happened before, it was because the fuel level was too low, but the fuel guage was showing 1/4 tank, so I didn't think it was that...
Did a forums search, but couldn’t find any refs to my question , so please move my post to the correct place if wrong.
I am having a
Webasto Air Top 2000 STC VW External Mount Air Heater Diesel
installed in a SWB T6 camper conversion.
As it’s a diesel it needs to be under slung.
Has anyone...
From the factory T6 Webasto aux/parking (water) heater comes configured to heat cabin only.
Up here in Finland the vans come with overhead control/timer panel to allow the use of timer or remote to switch on engine and cabin preheating before setting off. The heater is configured by dealer to...
On my 2017 T6, I have a Webasto auxiliary/water heater and Eberspacher air/parking heater fitted at factory. The remote and timer only controls the Eberspacher air/parking heater. The Webasto aux/water heater only kicks in whilst the engine is running and the outside temp is 5 degrees or below...
