windscreen washer jets
  1. E
    Another Screen Washers thread
    Hi team, another one, and yes have searched! I am a BMW wrecker, but we have a 2017 VW Transporter T6 FSI which we use as our parts van, WV1ZZZ7HZGH061474 It is a brilliant van and I really enjoy driving it! Having trouble with the windscreen washer not working when pull the stalk. It started...
  2. stupot
    Rear wash wipe underwhelming squirt… is it just me? Maybe it’s an age thing?
    Hi folks would appreciate a comparison test! Rear washer nozzle was missing, turns out previous owner had snapped it off so had to drill out the plastic that remained. Fitted new nozzle. Only squirts halfway up the rear screen.. is this lack of squirt range normal? Is it a sign of my pump being...
  3. A
    Connection to washer jets
    Hi Jets not working and found the connectors loose under the bonnet pumping out water! I cannot see how to attach to the nozzles and cannot find any descriptions here, or online save for a vague reference that in a T5 they are hidden, hard to get to and a push fit. Anyone got anything more...
  4. I
    Wiper washer dribbling at jets
    I have a strange problem on my t5 the window washer failed it was leaking at the bonnet joint I've rejoined it but hardly getting anything from the jets I've blown them out they seem ok at the joint if I break the split it's coming out fine I've changed the washer pump had all the lines checked...
  5. B
    washer nozzles - can’t adjust them
    hello this may sound like a stupid question but are the washer nozzles on the T6.1 fixed in position and you are not supposed to move them? The washer on the passenger side doesn’t seem to put enough water out to the left and up high enough so that when the wipers wipe it always leaves a smear...
  6. Gazdeth
    T6 bonnet removal
    Hi All, I need to remove my bonnet to send it off for a paint job. I can see how to take the strut off and the 4 bolts holding it on but any pointers on how to remove the unit that passes water to the washers? Does it just pull off and join to the washer units? Cheers in advance.
  7. 4
    Heated windshield washers installed?
    Hello all. First. English is not my native language. So I hope you understand me. I have a question. It has been cold here in Holland the last few days. The windshield washers were frozen. If all is well, the nozzles should be heated. Does anyone know how I can check that?
  8. mmi
    [T6_modified] Headlight washer - manual activation
    From factory headlight washer does it's job together with windscreen washer whenever the headlights are on, thus always a burst for the first windscreen wash after engine startup, then a burst for every 10th windscreen wash. Did some investigation if the washer could have been activated the...
  9. Jlo
    Uneven Windscreen washer Jets
    Hey all, I've got uneven windscreen washers jets with jets working better on the passenger side better than the drivers side. I do get some water out the drivers side but it's noticeably weaker and would like to fix it... Is there somthing restricting the flow? Is there somthing I can check...
  10. Niknak
    Sold Washer bottle neck
    Brand new Genuine washer bottle neck for t6, £10 bought one forgot and got another
  11. J
    Washer fluid level sensor..
    Hi, Can I disable the low washer fluid sensor using VCDS?
  12. S
    T6 windscreen washer not working reliably
    Windscreen washer stopped working just before van (2017 Highline) went in for service at a VW specialist (wipers were are fine and are still working). I told them about it and they said it's probably because the bonnet wasn't properly shut and lo and behold, the washer was working when I...
  13. Pauly
    T6 Washers & Wipers Wiring Diagram 2017
    Wash/Wipe System Circuit Diagrams Includes front and rear screens, LED headlights washers and heated washer jets VIP Membership is required to download this document
  14. Lukavell
    Easy Mod...
    Apologies if this has been shared before but I havent seen it. I was disappointed with the windscreen washer jets on my caravelle. They were the three separate jet types, my 2003 velle had much better type that sprays one wide arc. I found some on Amazon and changed them over this afternoon in...
  15. Alan Croft
    Heated washer jets
    so just got a bonus win on this. I was going to look into ordering the parts for this as I didn’t think mine had them. However my friend at VW has checked and the van has them. They only come on with the heated screen though?? Must remember to leave it on for longer to de-ice them in future...
