wiper motor
  1. MrG
    For Sale Rear wiper motor cover 3 months old - £12 Posted
    3 month old rear wiper motor cover. Really tidies up the tailgate even if you dont have a wiper. Only selling as my Van shades arrived. £12 posted (with all fixings included - these are an extra if purchased new)
  2. Texxaco
    Lack of front wipers
    Imagine, throw warm water on your frozen windscreen, get in the van, flick the wipers on and nowt! Try again… nothing. Trip to @Dav-Tec early morning, thankfully no wipers required on my journey. Phew!! Chris scans the van with VCDS, looks like a replacement stalk, ordered, fitted, still no...
  3. S
    2019 Combi Edition Wipers & Washers not working...
    Hello if anyone can help me please, as per title they have just stopped working front and back including the rain sensor. Tried removing the neutral from the battery, next step was fuses but I've no skill in electricals or mechanicals. Can't seem to find a diagram for the 2019 model, when I...
  4. S
    Windscreen Washer Reservoir & Pump
    So after looking into it the wipers are working but the washer pump isn’t no noise from the pump changed the fuse but it was fine in the 1st place have the battery disconnected for now to see if that resets it oh and I’ve changed the pump just in case. Any ideas? T6 17 plate t32 high line thanks...
  5. dave_b
    How do you remove the rear wiper motor cover?
    Just pull it?
  6. H
    Washer Wiper Woes [Resolved]
    Odd issue - front windscreen wipers don’t work from the stalk, but work fine on auto sensing. Windscreen wash doesn’t work for front and rear (replaced fuse and pump). Any ideas of anything else to check before booking it in? Many thanks
  7. Pauly
    T6 Barn Doors Wiring Diagram 2018
    Wing Door Circuit Diagram Covers rear door locking unit, heated glass and wash wipe system VIP Membership is required to download this document
  8. Skyliner33
    Removing Wiper blade arm?
    Ok, I’m trying to remove the wiper arms on a T6.1. Now on the T6 I just removed the bolt and with a bit of force they pulled off. However I can’t seem to shift them on this van
  9. B
    High Speed windscreen wiper not working
    Hi I have T6 2017, weird issue, the front wipers work fine for intermittent and medium speed but when I put it to highspeed, they stop, is this related to fuse or relay issue? any help would be appreciated. Thanks
  10. S
    Resolved: Possible Faulty rain sensor?
    Hi, I am new on here and new to T6 ownership. I have just purchased a pre reg 69 reg Kombi Highline, which appears to have an issue with the windscreen wipers. Hopefully someone can help? Dealers are useless. When the windscreen wiper stalk is in the off position mine is still switched on. So...
  11. Pauly
    T6 Washers & Wipers Wiring Diagram 2017
    Wash/Wipe System Circuit Diagrams Includes front and rear screens, LED headlights washers and heated washer jets VIP Membership is required to download this document
  12. Littleblackflash
    Where Is Connection 2 (75a) In Main Harness?
    Now the racing season is finished I have time to do some jobs on my van. I've fitted a tailgate with a wiper and I'm now connecting the wiring for the wiper. I have the wiring diagram (thanks Pauly) which shows the connections, but one wire goes to "Connection 2 (75a) in main harness". Where is...
  13. Littleblackflash
    Auto Wipers - Retrofit?
    I've had my T6 almost 2 months now and I've just noticed I don't have auto rain sensing wipers. My van (soon to be camper) is a 65plate Highline and came with Auto headlights, but from what I can work out, not the auto wiper. How difficult is it to add the rain sensor? My van has a sensor on...
  14. Paul Holmes
    Tailgate retrofit wiper motor kit
    Hi newbie here I'm collecting my new van on Tuesday he has a solid tailgate so I want to retrofit heated glass and wiper motor kit has anyone carried out this any help gratefully received
  15. lough90
    Windscreen washer low-level indication
    Does anyone know what’s involved to install a screen wash low level switch. Could not believe that VW would produce a vehicle in this day and age that does not have this as standard …. :mad::mad::mad: Or does my van have a fault …… o_O
