wiring diagram
  1. Jarscott
    Electrical Wiring Diagram - Opinions/Advice?
    Hi all, I'm currently in the planning stages of my T6 camper conversion and working through the electrical system. I’ve attached below the diagram I've created of the layout I’m going for. I’d really appreciate any feedback or advice from those who’ve been through a similar build or have...
  2. H
    12V DC-DC & 240V Mains Hook Up & 1000W Inverter- Electrical system
    I am after fairly simple electrical set up as I am planning on spending 90% on sites with hook up and never more than couple nights away. I have done hours of research but struggling to get my head around the wiring and equipment needed. I am also wondering if I will need Victron BMV-712 Smart...
  3. TallPaul_S
    Upgrading the Factory Leisure Battery set up (+ additions)!
    This is my current set up in my 2018 Caravelle, a mess of wires of a Factory specced Eberspacher Auxiliary air heater and 2nd battery, plus a few extras fitted by the previous owner, all under the passenger seat: This is the wiring diagram as it sits: I've got the standard split charge...
  4. S
    Dash Switch Wiring
    Hi, I would like to use this switch to enable/disable the ignition signal that kills the light and power at the back of my converted T6. Does anyone have a wiring diagram and/or know if the connector that plugs into this can be sourced? Thank you very much!
  5. D
    Glove box wiring loom t6
    Hi all, I have just bought a glove box wiring loom off of ebay. Advertised as a aT6 glove box wiring loom, albeit also said originally from a Passat. I have the switch and the light, and have just ordered the 2 correct connectors for the switch and light as this loom does not have them. The...
  6. D
    Vw T6.1 transporter wiring
    Hi all, I am a proud owner of a VW T6.1 Transporter and it is currently being fully converted into a campervan!!! Ran into an issue on installing a double swivel for passenger seat. It has seat belt and occupancy sensors fitted. I understand it is likely linked to the airbag engagement system...
  7. waxinggibbous28
    T6.1 (tailgate) brake light wiring diagram
    Hi everyone. My first post I hope I don’t make and faux pas. I bought some black led lights to replace the red reflectors on the bumper of my t6.1 (tailgate) from eBay. They seem very simple but obviously no instructions when they arrived. They replace the reflectors with lights that you can...
  8. Pauly
    T6.1 Camping Equipment 2019
    Wiring diagram for camping equipment There are two different diagrams in this download covering both types of setups, these are PR codes A9A & A8L A8R I assume these cover different models ie ocean,beach etc VIP Membership is required to download this document
  9. J19WMK
    Wiring IGN Cable for DC to DC Charger - HELP
    Hi everyone, In the interest of saving myself some time and money; Can any help with “piggy-backing” a IGN cable for a DC to DC charger from the fuse box under the dash? Thanks
  10. Dav-Tec
    Test bench loom
    Done a quick search and couldn't find anything. Before I go digging drawings out and making my.own just wondered if anyone had made their own test bench loom for testing purposes? I have one I'm going to adapt so i can swap front a Transporter BCM/Gateway to a Caddy gateway as I tend to work on...
  11. Pauly
    T6.1 Footwell Lights (Front & Rear) Wiring Diagram 2019
    Front and rear footwell lights wiring diagram VIP Membership is required to download this document
  12. Pauly
    T6.1 Footwell Lights (Front) Wiring Diagram 2019
    Front footwell lights wiring diagram VIP Membership is required to download this document. Once you have upgraded to VIP Membership, click on the orange-colour Download button.
  13. Pauly
    T6.1 Rain Sensor RLS Wiring Diagram 2021
    Wiring diagram for RLS rain light sensor on windscreen VIP Membership is required to download this document
  14. Pauly
    T6.1 Heated Washer Jets Wiring Diagram 2020
    Wiring diagram for front windscreen heated washer nozzles Wiring diagram 82 for vehicles manufactured from Aug 2019 Wiring diagram 95 for vehicles manufactured from July 2020 VIP Membership is required to download this document
  15. Pauly
    T6.1 Front Camera For Assist Systems Wiring Diagram 2020
    Front camera wiring diagram for driver assist systems, this is the camera for lane change assist etc For front camera for HBA/main beam assist check here - T6.1 - Front Camera (HBA) Wiring Diagram VIP Membership is required to download this document
  16. Pauly
    T6.1 Front Camera (HBA) Wiring Diagram 2020
    Wiring diagram for front camera built into interior (rear view) mirror, this is for high beam assist/main beam assist camera only For front camera for other assist systems check this document instead - T6.1 - Front Camera For Assist Systems Wiring Diagram VIP Membership is required to download...
  17. Pauly
    T6.1 Reverse Camera Wiring Diagram 2021
    Rear view camera/rear assist wiring diagram VIP Membership is required to download this document
  18. Pauly
    T6.1 Alarm System Wiring Diagram 2019
    Factory fit alarm system wiring diagram VIP Membership is required to download this document
  19. Pauly
    T6.1 Earthing Wiring Diagram 2019
    Wiring diagram for complete earthing system showing earth designations for vehicle equipment For fault diagnosis please see in association with this document - T6.1 - VW T6.1 Earth Points VIP Membership is required to download this document
  20. Pauly
    T6.1 AWD (4 Motion) Wiring Diagram 2019
    Wiring diagram for four wheel drive system and associated control modules and equipment VIP Membership is required to download this document
