I had thought I had the solution until I tested it today so wondering if any bright spark has a solution (did search however didn't find the answer)
I was going to use the footwell LED power to light my knight rider bonnet light as having observed the LED light it looked ideal:
- would come on when unlocked
- would go off when ignition turned on
- would come on when ignition turned off
- would go off when locked
This was going to be one of two supplies using diodes the other being when ignition is live.
So I thought I would mock it up and found that it behaves like this:
- unlock the car and footwell light comes on as well as knight rider light - PERFECT.
- turn on the ignition and footwell light goes out as expected BUT knight rider light stays illuminated and then after 20 or 30 seconds, goes off, comes back on again and then is only partly lit.
- lock the car and footwell light goes out as as does knight rider light - PERFECT.
I am guessing there is still some voltage to the lamp when it is "off" which is impacting the knight rider and I guess the BCM is keeping it in standby mode or something?
So after all that does anyone know of a live feed that will come on when unlocking and go off with locking (either immediately or timed)
