2+1 kombi seat to 1+1 using centre shuttle seat?
Graeme_B
Can somebody confirm my understanding that i could simply replace the double seat on 2nd row with the middle seat from a shuttle 2nd row?
Thabks for getting back. Would the brackets for righthand double seat in 2+1 not work for middle seat?
Not sure I understand the question.
All floor brackets are the same. A middle shuttle seat would use the left pair from the double seat as is. The other side of your shuttle seat will need either two new brackets fitting in the floor or the right hand pair relocating. I fitted extra brackets to increase the seating permutations.
So yours will have the ones where the body of the tape measure is and the other end of the tape is where your new / relocated brackets will be. If you relocate, it will leave a hole in the flooring which may or may not be a problem.
Ian
Ah. Yes i see now. I was thinking the double used the centre bracket bracket positions but can see it only uses the left.
Will eventually have a kitchen unit down the RHS so no need for the right bracket!
I did something similiar, but only had the triple in the back so swapped that out for middle single then fitted new brackets by sliding door for single there.
With the smart bed fitted it still gives me the option of 6 seats if needed. 2 front, 2 middle and 2 rear and units down the side.
