2-way leisure battery terminals (that aren't for posts)
RobFlynn
To save space I'd prefer not to use the posts on my leisure battery and connect with bolts directly. I'd also like to connect two cables to the positive terminal. I doubt it's good practice to stack up two ring terminals on the terminal so have been looking for something like on the link below but not for use with posts.
Do these exist? Any advice?
I also consider blue sea option instead of busbar - but these are only 100A? Any alternative suggestions to save space? thx
If you are mostly looking to save height you could use a single cable to the battery post and a bus bar nearby in an area with space.
If you don't have much space you could use a power post instead of a bus bar:
