20 Inch Alloy Wheel Size Help
sportline56
Hi Guys I need a little bit of advice can you tell me if the wheel pictured would fit a t6 Kombi t32 4 Motion its from a Landrover discovery I know the wheel is 5 x 120 and the centre bore is 72.6mm 8.5j x 20 with a offset of 53 its the offset I can't work out if it will fit or do you need to use a spacer with it also its weight weighted at 930 kg am I right in assuming that a 275/40/20 1o6 w tyre would also be suitable thank you in advance
Tony
I ran 8.5" wheels, with an ET45 and I personally thought they sat a little too far inside the arch, and ideally needed spacers.
Your set-up will be 8mm further inside.
Welcome to the forum by the way @sportline56
Hi thank you for the welcome and I think being a 8.5j maybe a little to narrow as well so I will keep looking for some different alloys with weight rating above 860Kg
Also this is a great forum full of really helpful people with sound information and advice :)
Tony
