2018 VW Transporter T6 Highline kombi, 6 seats, 150bhp, DSG gearbox. 98,345 miles, but is used daily, so will go up. MOT until 19/02/26. Private plate has now been taken off, it’s now FP18OWH. Lovely condition, Highline specification which includes air con, cruise control, heated windscreen and mirrors, electric windows and mirrors, multifunction steering wheel, reverse sensors etc.
When I purchased the van, the rear had been professionally carpeted, and 6 led roof lights fitted.
Since owning it, I’ve had many additions fitted, these comprise of:
Beautiful and versatile Uberwagon Multiflex system. This comprises all of the following in a modular system; A Bluetti EB70 power unit which has 240v, 12v and USB outputs. The battery is charged while driving, but can also be charged from the mains, or from the 200w solar panels which are included. On board water tank with built in pump, this supplies the included kitchen pod (which can be simply removed if not in use) and the hand held shower also included. On board gas supply, which supplies the kitchen pod, but could also be used with any other gas item with the correct adapter. Kitchen pod comprises of two burner gas hob, and sink unit. Also included is a bed and mattress, which is surprisingly comfortable, and includes fittings to raise the head of the bed if wanted. Bike fork mounts are also included if you wish to use them. All of the above is simple to remove, if you need to use it as a van.
Leighton Vans staggered 20” alloys.
Awning strip fitted underneath the near side roof bar.
Black running bars.
Transporter HQ version 3 smoked led lights and indicators all around, a vast improvement on the pitiful VW headlights (original lights will be included).
Dedicated Alpine speaker upgrade, including sound deadening the doors, again, a vast improvement on the standard speakers. Also added speakers in the rear of the roof, so the kids in the back can hear the music too.
Transporter HQ ‘sounds like a Golf’ door seals, much quieter when you close the doors.
Westfalia removable tow bar, professionally fitted with dedicated 13 pin electrics coded to the van.
Comprehensive service history;
Inspection service 13/12/18
Oil change service 19/10/19
Inspection service, and interval service 28/5/20
Brake fluid change 4/5/21
Oil change service 21/8/21
Oil change service 30/4/22
Cam belt change 6/6/22
Brake fluid change 14/10/22
Since I’ve owned it, I’ve carried out the following service work;
Oil, filter and air filter changed, 24/3/23
Rear brake discs, front and rear pads changed 2/4/23
DSG oil and filter changed, 28/4/23
New battery fitted and coded, 3/12/23
Both rear wheel bearings changed 5/7/23
4 new tyres 5/10/23
New auxiliary belt and tensioner fitted 16/2/24
Oil and filter changed 20/3/24
New standard suspension all around, including front anti roll bar bushes and Meyle HD top mounts and drop links. New rear springs not fitted, but are included with the van, as are new anti roll bars. 25/4/24
Alternator clutch pulley replaced, and new belt 28/12/24.
New front tyres, and alignment carried out 10/2/25,
Oil, oil filter and fuel filter changed 5/2/25.
Also included for the winter are 4 standard wheels with almost new Continental tyres, bolts and trims. I’ve sprayed the wheels bronze, not a brilliant job, but they look ok !
I also have a used once Outdoor Revolution awning and annex which could possibly be negotiated to be included. See less See less See less
Black running bars.
4 new tyres 5/10/23
