Whilst I have my seats removed, I thought I'd take the opportunity to have an experiment with one of these:
hobbycomponents.com
After satisfying myself that it was fit for the intended purpose, I have wired it to switch the remote loop from the DC-DC charger. With this switch powered from the starter battery, its function is simply to turn off when it is below 5 degrees. (I chose 5 degrees but this can be set at whatever you like.)
This will prevent the DC-DC from from throwing 30A at a very cold lifepo4 battery. (I know that the internal BMS should do this job, but for £4 its worth the extra piece of mind!)
#keennottoburnmynewvan
W1209 Temperature control Switch
The W1209 is an incredibly low cost yet highly functional thermostat controller. With this module (HCTHER0006) you can intelligently control power to most types of electrical device based on the temperature sensed by the included high accuracy NTC temperature sensor. Although this module has an...
