4 motion, dsc and acc fault after hitting puddle
marsie
Sold up
Hi all, we are currently in the scottish highlands in our van. On Tuesday I hit a deep puddle and almost instantly got the following faults-
ACC fault (! On display when cruise selected)
DSC fault (skidmark warning light)
4 motion fault (difflock light on)
There are several faults on carista which won't clear and the 10a difflock mini fuse has blown
When I replaced the mini fuse I get a smell of hot wiring and the fuse blows within a few seconds.
Has anyone had any experience of this and know where to start looking. I am guessing water has got in somewhere but not sure where?? It's had a couple of days to dry out but still no joy
Thanks in advance
Code:
ECU info obtained with Carista 6.5.1 for Android:
VIN: WV1ZZZ7HZHH170414
Engine
Part #: 04L906056KN
Component: R4 2.0l BTD
Software version: 3776
ASAM/ODX identifier: EV_ECM20BTD03004L906056KN
Coding: 00254014436701080000 (hex)
Fault codes:
25796 Manufacturer-specific code
31343 Manufacturer-specific code
Transmission
Part #: 0BT300012C
Component: DSG DQ500-7A
Software version: 5302
ASAM/ODX identifier: EV_TCMDQ500021
Coding: 0014 (hex)
[No fault codes]
ABS
Part #: 7E0907379Q
Component: ESC
Software version: 0133
ASAM/ODX identifier: EV_Brake1ESCCONTIVN75XGP2
Coding: 517EC0986569847E8A790377A68621A679F700 (hex)
Fault codes:
08269 Manufacturer-specific code
Instrument cluster
Part #: 7E0920970S
Component: KOMBI
Software version: 1107
ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09
Coding: 740F010300 (hex)
Fault codes:
12653568 Manufacturer-specific code
Airbags
Part #: 7E0959655G
Component: VW10Airbag021
Software version: 0018
ASAM/ODX identifier: EV_AirbaVW10BPAVW12X
Coding: 000000000000000000000000000000003231 (hex)
[No fault codes]
Steering angle
Part #: 6R0959654
Component: LENKW.SENSOR
Software version: 0070
ASAM/ODX identifier: EV_LWSKLOVW25X
Coding: 01 (hex)
[No fault codes]
Headlight aiming
Part #: 6R0907357C
Component: AFS-ECU
Software version: 0050
ASAM/ODX identifier: EV_HeadlRegulVWLWRCC
Coding: 0FCE020001000000 (hex)
[No fault codes]
Parking/steering assist
Part #: 7E0919475AA
Component: PARKHILFE 8K
Software version: 0212
ASAM/ODX identifier: EV_VW75XParkAssis8K
Coding: 30810C (hex)
[No fault codes]
Heater & air conditioning
Part #: 7E0907047AK
Component: Climatic-T5
Software version: 0708
ASAM/ODX identifier: EV_ClimaticT5
Coding: 0000000003 (hex)
[No fault codes]
Trailer
Part #: 1K0907383F
Component: Anhaenger
Software version: 0100
ASAM/ODX identifier: [none]
Coding: 0100000000000000 (hex)
[No fault codes]
Central electronics
Part #: 7E0937090B
Component: BCM PQ25 Max4
Software version: 0744
Coding: A0AC393A0AF3341193284F606CEB9F74C084738960CD79603204003F0860 (hex)
[No fault codes]
CAN network gateway
Part #: 7E0909901
Component: GW-K-CAN TP20
Coding: 042307 (hex)
Fault codes:
01324 Control Module for All Wheel Drive (J492)
Immobilizer
Part #: 5K0953234
Component: IMMO
ASAM/ODX identifier: EV_Immo_UDS_VDD_RM09
Coding: 000000 (hex)
[No fault codes]
All-wheel-drive system
[ECU not present]
Adaptive cruise control
Part #: 7N0907572C
Component: ACC Bosch PQx
Software version: 0211
ASAM/ODX identifier: EV_ACCBEGVW361
Coding: 00005000FE0779 (hex)
Fault codes:
01058 Function - Constant Charge - Current
01059 Rotor Position Sensor (G159)
01051 Fuel MC Positioning Motor (V117)
01037 Window lifters thermal protection actively, HR
01043 Control Module, Incorrect Software Version
00259 ABS Inlet Valve - Right Front (N99)
Battery regulator
Part #: 7E0907534
Component: Batt.regelung
Coding: 030B1A73 (hex)
Fault codes:
02252 Generator
Infotainment system
Part #: 5C0035680E
Component: MU-S-ND-ER
Software version: 0363
ASAM/ODX identifier: EV_MUStd4CTSAT
Coding: 065700013C00000011111101008808001F0107D6002001004F (hex)
Fault codes:
06145 Manufacturer-specific code
Reactions: mmi
I'm afraid there are at least two separate failures....
(1)​
All-wheel-drive system [ECU not present]
I would start checking why there is no communication with Haldex-controller - most likely wiring problem under vehicle.
Instrument cluster Part #: 7E0920970S Component: KOMBI Software version: 1107 ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09 Coding: 740F010300 (hex) Fault codes: 12653568 Manufacturer-specific code
12653568 - Function Restricted due to Missing Message(s) - U1111 00 [008] - - [Steuergerät für Allrad: keine Kommunikation]
Also instrument cluster is complaining about missing communications with Haldex-controller
Most likely the disconnected Haldex-controller is causing "sympathy faults" at ACC
1058 - Databus - U1123 00 [009] - Received Error Message - FAULT_CIS_ECD_NOTAVAILABLE]​
1059 - Databus - U1123 00 [009] - Received Error Message - [FAULT_CIS_ESP_FAIL]​
1037 - Databus - U1123 00 [009] - Received Error Message - [FAULT_CIS_QDCACC_FAIL]​
1043 - Automatic Distance Control - B10E7 F0 [009] - Disconnected - [FAULT_CIS_TSK_IRREV_FAIL]​
(2)​
Battery regulator Part #: 7E0907534 Component: Batt.regelung Software version: 0744 ASAM/ODX identifier: [none] Coding: 030B1A73 (hex) Fault codes: 02252 Generator
Alternator is not communicating with battery regulator - fault 02252 and engine fault 25796
See e.g. here:
EDIT: Repaired:
(3)​
While under van please check also wiring around AdBlue tank and especially into the AdBlue injector in DPF.
Not exactly sure about this one because Carista doesn't always interpret codes correctly. The suspect fault code is 0259 in ACC (strange!?)
Anyways, the first task is get Haldex-controller back on line and see if the (3) is relevant any more.
EDIT: Fuse SC33 - 10 A deliveres power for
Rear differential lock switch -E121-​
Vacuum switch for rear differential lock -F363-​
All-wheel drive control unit -J492-​
Differential lock control unit -J187-​
♦ Differential lock valve 1 -N125-​
♦ Differential lock valve 2 -N126-​
Thanks guys, the van has had a stop start fault since I got it in January but that has never bothered me and also an occasional egr low flow fault.
But the acc, dsc and 4 motion all came on at the same time when I hit the puddle so hopefully they are linked.
When I try replacing the 10a (33 i think, 5 fuse down in middle row but dont have fusecard) difflock fuse I get a smell of hot wiring and the fuse pops within a few seconds
Looks like I need to get under the van when I get home. Where is the controller for the awd located?
Thanks MMI, will investigate when I get home and have access to some tools this weekend :cool:
Reactions: mmi
All sorted. Traced the fault to a overheated plug connector on a vacuum solenoid in front of the adblue tank. It looks as though the wiring has rubbed through and shorted itself when it got wet out just before the plug, this has melted the plug causing a more permanent short and thats why it didnt go away when it dried out. At the moment the wire is disconnected and insulated and all the faults have cleared:cool:.
Need to get a new solenoid and plug kit to do a permanent fix
Massive thanks to @mmi for his guidance and advice. If you are ever up my way call in and many beers will be coming your way :p20220607_181547.jpg20220607_181555.jpg20220607_182203.jpg
oh yes, a bit of a result. Priced up bits and it's about £30 in parts. Could have been a lot worse. Who would have thought a bit of a puddle could cause so many faults. Bit scary when you are 400 miles from home with hardly any tools and the dash lights up like a Christmas tree
Massive thanks to @mmi for his guidance and advice. If you are ever up my way call in and many beers will be coming your way :pView attachment 159635View attachment 159636View attachment 159637
Hi marsie,
I think I may have the same problem on my van at the moment. Where about a is the valve in relation to the ad blue tank?
Thanks!
