5mm H&R wheel spacers - anybody using them?
YellowHound
Photographer
T6 Legend
As per title.
I've got some McGard wheel bolts inbound. Due to the length increments that are available I can only get something a little too short or a little too long.
I've gone long...
Worst case is I will need to use a 5mm spacer on each hub.
Anybody using these - and if so is there enough of the hub centre remaining to seat the wheel?
TIA.
You could just cut the bolts down to the correct length, much easier and cheaper.
