8mm to 6mm kador please
Roobs
Does anyone know where to get 8mm to 6mm kador? I have a reimo rail and 6mm pulls through the c channel. I have read that this is an issue for some other people, but not most, and I have ‘solved’ this so far by attaching gaffer tape to one side so it doesn’t pull through. It looks messy though and after multiple uses will need replacing. I saw that someone managed to attach 8mm to 6mm using an industrial sewing machine but I don’t have access to this. Thanks in advance.
You could slide a double strip in to your rail at the same time as your awning
If you have a reimo rail you could use a pole & clamp to attach to your van.
quick question: I have a 'driveaway' kit.
The kador strip on the kit is about 18 inches longer than the awning rail, once inserted.
Should I trim it? Or is this intentionally long?
you can cut it, think its longer so it covers both swb and lwb
