9438747 - Driver side seat belt tension igniter: Resistance too high
M14DMR
Hi, new to the Forum and in need of some advice.
The airbag warning light came on after i removed the seat when carrying out some work on my leisure battery under the drivers seat. Fault code keeps re-appearing when I try to clear it using a Carista OBD2 reader.
Seat belt is working fine.
Does anyone have any advice on how to fix it?
I suspect the plug isn’t properly engaged. Have you checked everything you unplugged to remove the seat?
Thanks. I have already checked the single connection under the seat but can’t hurt to check again.
