Hi, i have just had a heated rear screen fitted. To my tailgate. Have any of you guys got part numbers of any relays and switches or anything that i will need, any help would be appreciated.
Thank You
The relay that controls this is inside the BCM so you just need to get the cabling installed from the rear to the bcm then add the dash button (part of heater panel controls) and you may need to add some cables from that to the BCM also then it will need coding in to activate it
There are some threads dotted around that have some info about this so i would do some digging first
